This case study creates a database file at installation time and saves a copy of the database when the package is removed.
This case study demonstrates the following techniques:
Using classes and class action scripts to perform special actions on different sets of objects
For more information, see Writing Class Action Scripts.
Using the space file to inform the pkgadd command that extra space is required to install this package properly
For more information on the space file, see Reserving Additional Space on a Target System.
Using the installf command to install a file not defined in the prototype and pkgmap files
To create a database file at installation and save a copy on removal for this case study, you must complete the following tasks:
Define three classes.
The package in this case study requires the following three classes
be defined in the CLASSES parameter:
The standard class of none, which contains a set of processes belonging in the subdirectory bin.
The admin class, which contains an executable file config and a directory containing data files.
The cfgdata class, which contains a directory.
Make the package collectively relocatable.
Notice in the prototype file that none of the path names begins with a slash or an environment variable. This indicates that they are collectively relocatable.
Calculate the amount of space the database file requires and create a space file to deliver with the package. This file notifies the pkgadd command that the package requires extra space and specifies how much.
Create a class action script for the admin class (i.admin).
The sample script initializes a database using the data files belonging to the admin class. To perform this task, it does the following:
Copies the source data file to its proper destination
Creates an empty file named config.data and assigns it to a class of cfgdata
Executes the bin/config command (delivered with the package and already installed) to populate the database file config.data using the data files belonging to the admin class
Executes the installf -f command to finalize installation of config.data
No special action is required for the admin class at removal time so no removal class action script is created. This means that all files and directories in the admin class are removed from the system.
Create a removal class action script for the cfgdata class (r.cfgdata).
The removal script makes a copy of the database file before it is deleted. No special action is required for this class at installation time, so no installation class action script is needed.
Remember that the input to a removal script is a list of path names
to remove. Path names always appear in reverse alphabetical order. This removal
script copies files to the directory named $PKGSAV. When all the path names have been processed, the script
then goes back and removes all directories and files associated with the cfgdata class.
The outcome of this removal script is to copy config.data
to $PKGSAV and then remove the config.data file and the data directory.
PKG=krazy NAME=KrAzY Applications CATEGORY=applications BASEDIR=/opt ARCH=SPARC VERSION=Version 1 CLASSES=none cfgdata admin |
i pkginfo i request i i.admin i r.cfgdata d none bin 555 root sys f none bin/process1 555 root other f none bin/process2 555 root other f none bin/process3 555 root other f admin bin/config 500 root sys d admin cfg 555 root sys f admin cfg/datafile1 444 root sys f admin cfg/datafile2 444 root sys f admin cfg/datafile3 444 root sys f admin cfg/datafile4 444 root sys d cfgdata data 555 root sys |
# extra space required by config data which is # dynamically loaded onto the system data 500 1 |
# PKGINST parameter provided by installation service # BASEDIR parameter provided by installation service while read src dest do cp $src $dest || exit 2 done # if this is the last time this script will be executed # during the installation, do additional processing here. if [ "$1" = ENDOFCLASS ] then # our config process will create a data file based on any changes # made by installing files in this class; make sure the data file # is in class `cfgdata' so special rules can apply to it during # package removal. installf -c cfgdata $PKGINST $BASEDIR/data/config.data f 444 root sys || exit 2 $BASEDIR/bin/config > $BASEDIR/data/config.data || exit 2 installf -f -c cfgdata $PKGINST || exit 2 fi exit 0 |
This illustrates a rare instance in which installf is appropriate in a class action script. Because a space file has been used to reserve room on a specific file system, this new file may be safely added even though it is not included in the pkgmap file.
# the product manager for this package has suggested that # the configuration data is so valuable that it should be # backed up to $PKGSAV before it is removed! while read path do # path names appear in reverse lexical order. mv $path $PKGSAV || exit 2 rm -f $path || exit 2 done exit 0 |
