A patch to a package is just a sparse package designed to overwrite certain files in the original. There is no real reason for shipping a sparse package except to save space on the delivery medium. You could also ship the entire original package with a few files changed, or provide access to the modified package over a network. As long as only those new files are actually different (the other files were not recompiled), the pkgadd command installs the differences. Review the following guidelines regarding patching packages.
A patch must not change the intended delivered behavior of the package—it is not a mechanism for installing new features. A patch is used to repair objects installed on the system.
If the system is complex enough, it is wise to establish a patch identification system which assures that no two patches replace the same file in an attempt to correct different aberrant behaviors. For instance, Sun patch base numbers are assigned mutually exclusive sets of files for which they are responsible.
It is necessary to be able to back out a patch.
It is crucial that the version number of the patch package be the same as that of the original package. This is true because a patch must not add functionality. You should keep track of the patch status of the package using a separate pkginfo file entry of the form
PATCH=patch_number |
If the package version is changed for a patch, you create another instance of the package and it becomes extremely difficult to manage the patched product. This method of progressive instance patching carried certain advantages in the early releases of the Solaris operating environment, but makes management of more complicated systems tedious.
As far as the packages that make up the Solaris operating environment are concerned, there should be only one copy of the package in the package database, although there may be multiple patched instances. In order to remove an object from an installed package (using the removef command) you need to figure out what instances own that file.
However, if your package (that is not part of the Solaris operating
environment) needs to determine the patch level of a particular package that is part of the Solaris operating environment, this becomes a problem
to be resolved here. The installation scripts can be quite large without significant
impact since they are not stored on the target file system. Using class action
scripts and various other procedure scripts, you can save changed files using
the PKGSAV
environment variable
(or to some other, more permanent directory) in order to allow backing out
installed patches. You can also monitor patch history by setting appropriate
environment variables through the request scripts. The scripts in the next sections assume that
there may be multiple patches whose numbering scheme carries some meaning
when applied to a single package. In this case, individual patch numbers represent
a subset of functionally related files within the package. Two different patch
numbers cannot change the same file.
In order to make a regular sparse package into a patch package, the scripts described in the following sections can simply be folded into the package. All of them are recognizable as standard package components with the exception of the last two which are named patch_checkinstall and patch_postinstall. Those two scripts can be incorporated into the backout package, if you want to include the ability to back out the patch. The scripts are fairly simple and their various tasks are straightforward.
This method of patching can be used to patch client systems, but client root directories on the server must have the correct permissions to allow reading by the user install or nobody.
The checkinstall script verifies that the patch is appropriate for this particular package. Once that is confirmed, it constructs the patch list and the patch info list, and then inserts them into the response file for incorporation into the package database.
A patch list is the list of patches that have affected the current package. This list of patches is recorded in the installed package in the pkginfo file with a line that might look like this:
PATCHLIST=patch_id patch_id ... |
A patch info list is the list of patches on which the current patch is dependent. This list of patches is also recorded in the pkginfo file with a line that might look like this.
PATCH_INFO_103203-01=Installed... Obsoletes:103201-01 Requires: \ Incompatibles: 120134-01 |
These lines (and their format) are declared as a public interface. Any company that ships patches for Solaris packages should update this list appropriately. When a patch is delivered, each package within the patch contains a checkinstall script that performs this task. That same checkinstall script also updates some other patch-specific parameters. This is the new patch architecture, which is called Direct Instance Patching.
In this example, both the original packages and their patches exist
in the same directory. The two original packages are named SUNWstuf.v1 and SUNWstuf.v2, and their patches are named SUNWstuf.p1 and SUNWstuf.p2. What this means
is that it could be very difficult for a procedure script to figure out what
directory these files came from, since everything in the package name after
the dot (“.”) is stripped for the PKG
parameter, and the PKGINST
environment variable refers to the installed instance not the
source instance. So the procedure scripts can find the source directory, the checkinstall script (which is always executed from the source directory)
makes the inquiry and passes the location on as the variable SCRIPTS_DIR. If there had been only one package in the source directory called SUNWstuf, then the procedure scripts could have found it using $INSTDIR/$PKG.
# checkinstall script to control a patch installation. # directory format options. # # @(#)checkinstall 1.6 96/09/27 SMI # # Copyright (c) 1995 by Sun Microsystems, Inc. # All rights reserved # PATH=/usr/sadm/bin:$PATH INFO_DIR=`dirname $0` INFO_DIR=`dirname $INFO_DIR` # one level up NOVERS_MSG="PaTcH_MsG 8 Version $VERSION of $PKG is not installed on this system." ALRDY_MSG="PaTcH_MsG 2 Patch number $Patch_label is already applied." TEMP_MSG="PaTcH_MsG 23 Patch number $Patch_label cannot be applied until all \ restricted patches are backed out." # Read the provided environment from what may have been a request script . $1 # Old systems can't deal with checkinstall scripts anyway if [ "$PATCH_PROGRESSIVE" = "true" ]; then exit 0 fi # # Confirm that the intended version is installed on the system. # if [ "${UPDATE}" != "yes" ]; then echo "$NOVERS_MSG" exit 3 fi # # Confirm that this patch hasn't already been applied and # that no other mix-ups have occurred involving patch versions and # the like. # Skip=0 active_base=`echo $Patch_label | nawk ' { print substr($0, 1, match($0, "Patchvers_pfx")-1) } '` active_inst=`echo $Patch_label | nawk ' { print substr($0, match($0, "Patchvers_pfx")+Patchvers_pfx_lnth) } '` # Is this a restricted patch? if echo $active_base | egrep -s "Patchstrict_str"; then is_restricted="true" # All restricted patches are backoutable echo "PATCH_NO_UNDO=" >> $1 else is_restricted="false" fi for patchappl in ${PATCHLIST}; do # Is this an ordinary patch applying over a restricted patch? if [ $is_restricted = "false" ]; then if echo $patchappl | egrep -s "Patchstrict_str"; then echo "$TEMP_MSG" exit 3; fi fi # Is there a newer version of this patch? appl_base=`echo $patchappl | nawk ' { print substr($0, 1, match($0, "Patchvers_pfx")-1) } '` if [ $appl_base = $active_base ]; then appl_inst=`echo $patchappl | nawk ' { print substr($0, match($0, "Patchvers_pfx")\ +Patchvers_pfx_lnth) } '` result=`expr $appl_inst \> $active_inst` if [ $result -eq 1 ]; then echo "PaTcH_MsG 1 Patch number $Patch_label is \ superceded by the already applied $patchappl." exit 3 elif [ $appl_inst = $active_inst ]; then # Not newer, it's the same if [ "$PATCH_UNCONDITIONAL" = "true" ]; then if [ -d $PKGSAV/$Patch_label ]; then echo "PATCH_NO_UNDO=true" >> $1 fi else echo "$ALRDY_MSG" exit 3; fi fi fi done # Construct a list of applied patches in order echo "PATCHLIST=${PATCHLIST} $Patch_label" >> $1 # # Construct the complete list of patches this one obsoletes # ACTIVE_OBSOLETES=$Obsoletes_label if [ -n "$Obsoletes_label" ]; then # Merge the two lists echo $Obsoletes_label | sed 'y/\ /\n/' | \ nawk -v PatchObsList="$PATCH_OBSOLETES" ' BEGIN { printf("PATCH_OBSOLETES="); PatchCount=split(PatchObsList, PatchObsComp, " "); for(PatchIndex in PatchObsComp) { Atisat=match(PatchObsComp[PatchIndex], "@"); PatchObs[PatchIndex]=substr(PatchObsComp[PatchIndex], \ 0, Atisat-1); PatchObsCnt[PatchIndex]=substr(PatchObsComp\ [PatchIndex], Atisat+1); } } { Inserted=0; for(PatchIndex in PatchObs) { if (PatchObs[PatchIndex] == $0) { if (Inserted == 0) { PatchObsCnt[PatchIndex]=PatchObsCnt\ [PatchIndex]+1; Inserted=1; } else { PatchObsCnt[PatchIndex]=0; } } } if (Inserted == 0) { printf ("%s@1 ", $0); } next; } END { for(PatchIndex in PatchObs) { if ( PatchObsCnt[PatchIndex] != 0) { printf("%s@%d ", PatchObs[PatchIndex], \ PatchObsCnt[PatchIndex]); } } printf("\n"); } ' >> $1 # Clear the parameter since it has already been used. echo "Obsoletes_label=" >> $1 # Pass it's value on to the preinstall under another name echo "ACTIVE_OBSOLETES=$ACTIVE_OBSOLETES" >> $1 fi # # Construct PATCH_INFO line for this package. # tmpRequire=`nawk -F= ' $1 ~ /REQUIR/ { print $2 } ' $INFO_DIR/pkginfo ` tmpIncompat=`nawk -F= ' $1 ~ /INCOMPAT/ { print $2 } ' $INFO_DIR/pkginfo ` if [ -n "$tmpRequire" ] && [ -n "$tmpIncompat" ] then echo "PATCH_INFO_$Patch_label=Installed: `date` From: `uname -n` \ Obsoletes: $ACTIVE_OBSOLETES Requires: $tmpRequire \ Incompatibles: $tmpIncompat" >> $1 elif [ -n "$tmpRequire" ] then echo "PATCH_INFO_$Patch_label=Installed: `date` From: `uname -n` \ Obsoletes: $ACTIVE_OBSOLETES Requires: $tmpRequire \ Incompatibles: " >> $1 elif [ -n "$tmpIncompat" ] then echo "PATCH_INFO_$Patch_label=Installed: `date` From: `uname -n` \ Obsoletes: $ACTIVE_OBSOLETES Requires: Incompatibles: \ $tmpIncompat" >> $1 else echo "PATCH_INFO_$Patch_label=Installed: `date` From: `uname -n` \ Obsoletes: $ACTIVE_OBSOLETES Requires: Incompatibles: " >> $1 fi # # Since this script is called from the delivery medium and we may be using # dot extensions to distinguish the different patch packages, this is the # only place we can, with certainty, trace that source for our backout # scripts. (Usually $INST_DATADIR would get us there). # echo "SCRIPTS_DIR=`dirname $0`" >> $1 # If additional operations are required for this package, place # those package-specific commands here. #XXXSpecial_CommandsXXX# exit 0 |
The preinstall script initializes the prototype file, information files, and installation scripts for the backout package to be constructed. This script is very simple and the remaining scripts in this example only allow a backout package to describe regular files.
If you wanted to restore symbolic links, hard links, devices, and named pipes in a backout package, you could modify the preinstall script to use the pkgproto command to compare the delivered pkgmap file with the installed files, and then create a prototype file entry for each non-file to be changed in the backout package. The method you should use is similar to the method in the class action script.
The scripts patch_checkinstall and patch_postinstall are inserted into the package source tree from the preinstall script. These two scripts undo what the patch does.
# This script initializes the backout data for a patch package # directory format options. # # @(#)preinstall 1.5 96/05/10 SMI # # Copyright (c) 1995 by Sun Microsystems, Inc. # All rights reserved # PATH=/usr/sadm/bin:$PATH recovery="no" if [ "$PKG_INSTALL_ROOT" = "/" ]; then PKG_INSTALL_ROOT="" fi # Check to see if this is a patch installation retry. if [ "$INTERRUPTION" = "yes" ]; then if [ -d "$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST" ] || [ -d \ "$PATCH_BUILD_DIR/$Patch_label.$PKGINST" ]; then recovery="yes" fi fi if [ -n "$PATCH_BUILD_DIR" -a -d "$PATCH_BUILD_DIR" ]; then BUILD_DIR="$PATCH_BUILD_DIR/$Patch_label.$PKGINST" else BUILD_DIR="$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST" fi FILE_DIR=$BUILD_DIR/files RELOC_DIR=$BUILD_DIR/files/reloc ROOT_DIR=$BUILD_DIR/files/root PROTO_FILE=$BUILD_DIR/prototype PKGINFO_FILE=$BUILD_DIR/pkginfo THIS_DIR=`dirname $0` if [ "$PATCH_PROGRESSIVE" = "true" ]; then # If this is being used in an old-style patch, insert # the old-style script commands here. #XXXOld_CommandsXXX# exit 0 fi # # Unless specifically denied, initialize the backout patch data by # creating the build directory and copying over the original pkginfo # which pkgadd saved in case it had to be restored. # if [ "$PATCH_NO_UNDO" != "true" ] && [ "$recovery" = "no" ]; then if [ -d $BUILD_DIR ]; then rm -r $BUILD_DIR fi # If this is a retry of the same patch then recovery is set to # yes. Which means there is a build directory already in # place with the correct backout data. if [ "$recovery" = "no" ]; then mkdir $BUILD_DIR mkdir -p $RELOC_DIR mkdir $ROOT_DIR fi # # Here we initialize the backout pkginfo file by first # copying over the old pkginfo file and themn adding the # ACTIVE_PATCH parameter so the backout will know what patch # it's backing out. # # NOTE : Within the installation, pkgparam returns the # original data. # pkgparam -v $PKGINST | nawk ' $1 ~ /PATCHLIST/ { next; } $1 ~ /PATCH_OBSOLETES/ { next; } $1 ~ /ACTIVE_OBSOLETES/ { next; } $1 ~ /Obsoletes_label/ { next; } $1 ~ /ACTIVE_PATCH/ { next; } $1 ~ /Patch_label/ { next; } $1 ~ /UPDATE/ { next; } $1 ~ /SCRIPTS_DIR/ { next; } $1 ~ /PATCH_NO_UNDO/ { next; } $1 ~ /INSTDATE/ { next; } $1 ~ /PKGINST/ { next; } $1 ~ /OAMBASE/ { next; } $1 ~ /PATH/ { next; } { print; } ' > $PKGINFO_FILE echo "ACTIVE_PATCH=$Patch_label" >> $PKGINFO_FILE echo "ACTIVE_OBSOLETES=$ACTIVE_OBSOLETES" >> $PKGINFO_FILE # And now initialize the backout prototype file with the # pkginfo file just formulated. echo "i pkginfo" > $PROTO_FILE # Copy over the backout scripts including the undo class # action scripts for script in $SCRIPTS_DIR/*; do srcscript=`basename $script` targscript=`echo $srcscript | nawk ' { script=$0; } /u\./ { sub("u.", "i.", script); print script; next; } /patch_/ { sub("patch_", "", script); print script; next; } { print "dont_use" } '` if [ "$targscript" = "dont_use" ]; then continue fi echo "i $targscript=$FILE_DIR/$targscript" >> $PROTO_FILE cp $SCRIPTS_DIR/$srcscript $FILE_DIR/$targscript done # # Now add entries to the prototype file that won't be passed to # class action scripts. If the entry is brand new, add it to the # deletes file for the backout package. # Our_Pkgmap=`dirname $SCRIPTS_DIR`/pkgmap BO_Deletes=$FILE_DIR/deletes nawk -v basedir=${BASEDIR:-/} ' BEGIN { count=0; } { token = $2; ftype = $1; } $1 ~ /[#\!:]/ { next; } $1 ~ /[0123456789]/ { if ( NF >= 3) { token = $3; ftype = $2; } else { next; } } { if (ftype == "i" || ftype == "e" || ftype == "f" || ftype == \ "v" || ftype == "d") { next; } } { equals=match($4, "=")-1; if ( equals == -1 ) { print $3, $4; } else { print $3, substr($4, 0, equals); } } ' < $Our_Pkgmap | while read class path; do # # NOTE: If pkgproto is passed a file that is # actually a hard link to another file, it # will return ftype "f" because the first link # in the list (consisting of only one file) is # viewed by pkgproto as the source and always # gets ftype "f". # # If this isn't replacing something, then it # just goes to the deletes list. # if valpath -l $path; then Chk_Path="$BASEDIR/$path" Build_Path="$RELOC_DIR/$path" Proto_From="$BASEDIR" else # It's an absolute path Chk_Path="$PKG_INSTALL_ROOT$path" Build_Path="$ROOT_DIR$path" Proto_From="$PKG_INSTALL_ROOT" fi # # Hard links have to be restored as regular files. # Unlike the others in this group, an actual # object will be required for the pkgmk. # if [ -f "$Chk_Path" ]; then mkdir -p `dirname $Build_Path` cp $Chk_Path $Build_Path cd $Proto_From pkgproto -c $class "$Build_Path=$path" 1>> \ $PROTO_FILE 2> /dev/null cd $THIS_DIR elif [ -h "$Chk_Path" -o \ -c "$Chk_Path" -o \ -b "$Chk_Path" -o \ -p "$Chk_Path" ]; then pkgproto -c $class "$Chk_Path=$path" 1>> \ $PROTO_FILE 2> /dev/null else echo $path >> $BO_Deletes fi done fi # If additional operations are required for this package, place # those package-specific commands here. #XXXSpecial_CommandsXXX# exit 0 |
The class action script creates a copy of each file that replaces an existing file and adds a corresponding line to the prototype file for the backout package. This is all done with fairly simple nawk scripts. The class action script receives a list of source/destination pairs consisting of ordinary files that do not match the corresponding installed files. Symbolic links and other non-files must be dealt with in the preinstall script.
# This class action script copies the files being replaced # into a package being constructed in $BUILD_DIR. This class # action script is only appropriate for regular files that # are installed by simply copying them into place. # # For special package objects such as editable files, the patch # producer must supply appropriate class action scripts. # # directory format options. # # @(#)i.script 1.6 96/05/10 SMI # # Copyright (c) 1995 by Sun Microsystems, Inc. # All rights reserved # PATH=/usr/sadm/bin:$PATH ECHO="/usr/bin/echo" SED="/usr/bin/sed" PKGPROTO="/usr/bin/pkgproto" EXPR="/usr/bin/expr" # used by dirname MKDIR="/usr/bin/mkdir" CP="/usr/bin/cp" RM="/usr/bin/rm" MV="/usr/bin/mv" recovery="no" Pn=$$ procIdCtr=0 CMDS_USED="$ECHO $SED $PKGPROTO $EXPR $MKDIR $CP $RM $MV" LIBS_USED="" if [ "$PKG_INSTALL_ROOT" = "/" ]; then PKG_INSTALL_ROOT="" fi # Check to see if this is a patch installation retry. if [ "$INTERRUPTION" = "yes" ]; then if [ -d "$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST" ] || \ [ -d "$PATCH_BUILD_DIR/$Patch_label.$PKGINST" ]; then recovery="yes" fi fi if [ -n "$PATCH_BUILD_DIR" -a -d "$PATCH_BUILD_DIR" ]; then BUILD_DIR="$PATCH_BUILD_DIR/$Patch_label.$PKGINST" else BUILD_DIR="$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST" fi FILE_DIR=$BUILD_DIR/files RELOC_DIR=$FILE_DIR/reloc ROOT_DIR=$FILE_DIR/root BO_Deletes=$FILE_DIR/deletes PROGNAME=`basename $0` if [ "$PATCH_PROGRESSIVE" = "true" ]; then PATCH_NO_UNDO="true" fi # Since this is generic, figure out the class. Class=`echo $PROGNAME | nawk ' { print substr($0, 3) }'` # Since this is an update, $BASEDIR is guaranteed to be correct BD=${BASEDIR:-/} cd $BD # # First, figure out the dynamic libraries that can trip us up. # if [ -z "$PKG_INSTALL_ROOT" ]; then if [ -x /usr/bin/ldd ]; then LIB_LIST=`/usr/bin/ldd $CMDS_USED | sort -u | nawk ' $1 ~ /\// { continue; } { printf "%s ", $3 } '` else LIB_LIST="/usr/lib/libc.so.1 /usr/lib/libdl.so.1 \ /usr/lib/libw.so.1 /usr/lib/libintl.so.1 /usr/lib/libadm.so.1 \ /usr/lib/libelf.so.1" fi fi # # Now read the list of files in this class to be replaced. If the file # is already in place, then this is a change and we need to copy it # over to the build directory if undo is allowed. If it's a new entry # (No $dst), then it goes in the deletes file for the backout package. # procIdCtr=0 while read src dst; do if [ -z "$PKG_INSTALL_ROOT" ]; then Chk_Path=$dst for library in $LIB_LIST; do if [ $Chk_Path = $library ]; then $CP $dst $dst.$Pn LIBS_USED="$LIBS_USED $dst.$Pn" LD_PRELOAD="$LIBS_USED" export LD_PRELOAD fi done fi if [ "$PATCH_PROGRESSIVE" = "true" ]; then # If this is being used in an old-style patch, insert # the old-style script commands here. #XXXOld_CommandsXXX# echo >/dev/null # dummy fi if [ "${PATCH_NO_UNDO}" != "true" ]; then # # Here we construct the path to the appropriate source # tree for the build. First we try to strip BASEDIR. If # there's no BASEDIR in the path, we presume that it is # absolute and construct the target as an absolute path # by stripping PKG_INSTALL_ROOT. FS_Path is the path to # the file on the file system (for deletion purposes). # Build_Path is the path to the object in the build # environment. # if [ "$BD" = "/" ]; then FS_Path=`$ECHO $dst | $SED s@"$BD"@@` else FS_Path=`$ECHO $dst | $SED s@"$BD/"@@` fi # If it's an absolute path the attempt to strip the # BASEDIR will have failed. if [ $dst = $FS_Path ]; then if [ -z "$PKG_INSTALL_ROOT" ]; then FS_Path=$dst Build_Path="$ROOT_DIR$dst" else Build_Path="$ROOT_DIR`echo $dst | \ sed s@"$PKG_INSTALL_ROOT"@@`" FS_Path=`echo $dst | \ sed s@"$PKG_INSTALL_ROOT"@@` fi else Build_Path="$RELOC_DIR/$FS_Path" fi if [ -f $dst ]; then # If this is replacing something cd $FILE_DIR # # Construct the prototype file entry. We replace # the pointer to the filesystem object with the # build directory object. # $PKGPROTO -c $Class $dst=$FS_Path | \ $SED -e s@=$dst@=$Build_Path@ >> \ $BUILD_DIR/prototype # Now copy over the file if [ "$recovery" = "no" ]; then DirName=`dirname $Build_Path` $MKDIR -p $DirName $CP -p $dst $Build_Path else # If this file is already in the build area skip it if [ -f "$Build_Path" ]; then cd $BD continue else DirName=`dirname $Build_Path` if [ ! -d "$DirName" ]; then $MKDIR -p $DirName fi $CP -p $dst $Build_Path fi fi cd $BD else # It's brand new $ECHO $FS_Path >> $BO_Deletes fi fi # If special processing is required for each src/dst pair, # add that here. # #XXXSpecial_CommandsXXX# # $CP $src $dst.$$$procIdCtr if [ $? -ne 0 ]; then $RM $dst.$$$procIdCtr 1>/dev/null 2>&1 else $MV -f $dst.$$$procIdCtr $dst for library in $LIB_LIST; do if [ "$library" = "$dst" ]; then LD_PRELOAD="$dst" export LD_PRELOAD fi done fi procIdCtr=`expr $procIdCtr + 1` done # If additional operations are required for this package, place # those package-specific commands here. #XXXSpecial_CommandsXXX# # # Release the dynamic libraries # for library in $LIBS_USED; do $RM -f $library done exit 0 |
The postinstall script creates the backout package using the information provided by the other scripts. Since the pkgmk and pkgtrans commands do not require the package database, they can be executed within a package installation.
In the example, undoing the patch is permitted by constructing a stream
format package in the save directory (using the PKGSAV
environment variable). It is not obvious, but this package
must be in stream format, because the save directory gets moved around during
a pkgadd operation. If the pkgadd command
is applied to a package in its own save directory, assumptions about where
the package source is at any given time become very unreliable. A stream format
package is unpacked into a temporary directory and installed from there. (A
directory format package would begin installing from the save directory and
find itself suddenly relocated during a pkgadd fail-safe
operation.)
To determine which patches are applied to a package, use this command:
$ pkgparam SUNWstuf PATCHLIST |
With the exception of PATCHLIST
which is a Sun public interface, there is nothing significant in the parameter
names in this example. Instead of PATCH you could use the
traditional SUNW_PATCHID and the various other lists such
as PATCH_EXCL and PATCH_REQD could be
renamed accordingly.
If certain patch packages depend upon other patch packages which are available from the same medium, the checkinstall script could determine this and create a script to be executed by the postinstall script in the same way that the upgrade example (see Upgrading Packages) does.
# This script creates the backout package for a patch package # # directory format options. # # @(#) postinstall 1.6 96/01/29 SMI # # Copyright (c) 1995 by Sun Microsystems, Inc. # All rights reserved # # Description: # Set the TYPE parameter for the remote file # # Parameters: # none # # Globals set: # TYPE set_TYPE_parameter () { if [ ${PATCH_UNDO_ARCHIVE:?????} = "/dev" ]; then # handle device specific stuff TYPE="removable" else TYPE="filesystem" fi } # # Description: # Build the remote file that points to the backout data # # Parameters: # $1: the un/compressed undo archive # # Globals set: # UNDO, STATE build_remote_file () { remote_path=$PKGSAV/$Patch_label/remote set_TYPE_parameter STATE="active" if [ $1 = "undo" ]; then UNDO="undo" else UNDO="undo.Z" fi cat > $remote_path << EOF # Backout data stored remotely TYPE=$TYPE FIND_AT=$ARCHIVE_DIR/$UNDO STATE=$STATE EOF } PATH=/usr/sadm/bin:$PATH if [ "$PKG_INSTALL_ROOT" = "/" ]; then PKG_INSTALL_ROOT="" fi if [ -n "$PATCH_BUILD_DIR" -a -d "$PATCH_BUILD_DIR" ]; then BUILD_DIR="$PATCH_BUILD_DIR/$Patch_label.$PKGINST" else BUILD_DIR="$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST" fi if [ ! -n "$PATCH_UNDO_ARCHIVE" ]; then PATCH_UNDO_ARCHIVE="none" fi FILE_DIR=$BUILD_DIR/files RELOC_DIR=$FILE_DIR/reloc ROOT_DIR=$FILE_DIR/root BO_Deletes=$FILE_DIR/deletes THIS_DIR=`dirname $0` PROTO_FILE=$BUILD_DIR/prototype TEMP_REMOTE=$PKGSAV/$Patch_label/temp if [ "$PATCH_PROGRESSIVE" = "true" ]; then # remove the scripts that are left behind install_scripts=`dirname $0` rm $install_scripts/checkinstall \ $install_scripts/patch_checkinstall $install_scripts/patch_postinstall # If this is being used in an old-style patch, insert # the old-style script commands here. #XXXOld_CommandsXXX# exit 0 fi # # At this point we either have a deletes file or we don't. If we do, # we create a prototype entry. # if [ -f $BO_Deletes ]; then echo "i deletes=$BO_Deletes" >> $BUILD_DIR/prototype fi # # Now delete everything in the deletes list after transferring # the file to the backout package and the entry to the prototype # file. Remember that the pkgmap will get the CLIENT_BASEDIR path # but we have to actually get at it using the BASEDIR path. Also # remember that removef will import our PKG_INSTALL_ROOT # Our_Deletes=$THIS_DIR/deletes if [ -f $Our_Deletes ]; then cd $BASEDIR cat $Our_Deletes | while read path; do Reg_File=0 if valpath -l $path; then Client_Path="$CLIENT_BASEDIR/$path" Build_Path="$RELOC_DIR/$path" Proto_Path=$BASEDIR/$path else # It's an absolute path Client_Path=$path Build_Path="$ROOT_DIR$path" Proto_Path=$PKG_INSTALL_ROOT$path fi # Note: If the file isn't really there, pkgproto # doesn't write anything. LINE=`pkgproto $Proto_Path=$path` ftype=`echo $LINE | nawk '{ print $1 }'` if [ $ftype = "f" ]; then Reg_File=1 fi if [ $Reg_File = 1 ]; then # Add source file to the prototype entry if [ "$Proto_Path" = "$path" ]; then LINE=`echo $LINE | sed -e s@$Proto_Path@$Build_Path@2` else LINE=`echo $LINE | sed -e s@$Proto_Path@$Build_Path@` fi DirName=`dirname $Build_Path` # make room in the build tree mkdir -p $DirName cp -p $Proto_Path $Build_Path fi # Insert it into the prototype file echo $LINE 1>>$PROTO_FILE 2>/dev/null # Remove the file only if it's OK'd by removef rm `removef $PKGINST $Client_Path` 1>/dev/null 2>&1 done removef -f $PKGINST rm $Our_Deletes fi # # Unless specifically denied, make the backout package. # if [ "$PATCH_NO_UNDO" != "true" ]; then cd $BUILD_DIR # We have to build from here. if [ "$PATCH_UNDO_ARCHIVE" != "none" ]; then STAGE_DIR="$PATCH_UNDO_ARCHIVE" ARCHIVE_DIR="$PATCH_UNDO_ARCHIVE/$Patch_label/$PKGINST" mkdir -p $ARCHIVE_DIR mkdir -p $PKGSAV/$Patch_label else if [ -d $PKGSAV/$Patch_label ]; then rm -r $PKGSAV/$Patch_label fi STAGE_DIR=$PKGSAV ARCHIVE_DIR=$PKGSAV/$Patch_label mkdir $ARCHIVE_DIR fi pkgmk -o -d $STAGE_DIR 1>/dev/null 2>&1 pkgtrans -s $STAGE_DIR $ARCHIVE_DIR/undo $PKG 1>/dev/null 2>&1 compress $ARCHIVE_DIR/undo retcode=$? if [ "$PATCH_UNDO_ARCHIVE" != "none" ]; then if [ $retcode != 0 ]; then build_remote_file "undo" else build_remote_file "undo.Z" fi fi rm -r $STAGE_DIR/$PKG cd .. rm -r $BUILD_DIR # remove the scripts that are left behind install_scripts=`dirname $0` rm $install_scripts/checkinstall $install_scripts/patch_\ checkinstall $install_scripts/patch_postinstall fi # # Since this apparently worked, we'll mark as obsoleted the prior # versions of this patch - installpatch deals with explicit obsoletions. # cd ${PKG_INSTALL_ROOT:-/} cd var/sadm/pkg active_base=`echo $Patch_label | nawk ' { print substr($0, 1, match($0, "Patchvers_pfx")-1) } '` List=`ls -d $PKGINST/save/${active_base}*` if [ $? -ne 0 ]; then List="" fi for savedir in $List; do patch=`basename $savedir` if [ $patch = $Patch_label ]; then break fi # If we get here then the previous patch gets deleted if [ -f $savedir/undo ]; then mv $savedir/undo $savedir/obsolete echo $Patch_label >> $savedir/obsoleted_by elif [ -f $savedir/undo.Z ]; then mv $savedir/undo.Z $savedir/obsolete.Z echo $Patch_label >> $savedir/obsoleted_by elif [ -f $savedir/remote ]; then `grep . $PKGSAV/$patch/remote | sed 's/STATE=.*/STATE=obsolete/ ' > $TEMP_REMOTE` rm -f $PKGSAV/$patch/remote mv $TEMP_REMOTE $PKGSAV/$patch/remote rm -f $TEMP_REMOTE echo $Patch_label >> $savedir/obsoleted_by elif [ -f $savedir/obsolete -o -f $savedir/obsolete.Z ]; then echo $Patch_label >> $savedir/obsoleted_by fi done # If additional operations are required for this package, place # those package-specific commands here. #XXXSpecial_CommandsXXX# exit 0 |
# checkinstall script to validate backing out a patch. # directory format option. # # @(#)patch_checkinstall 1.2 95/10/10 SMI # # Copyright (c) 1995 by Sun Microsystems, Inc. # All rights reserved # PATH=/usr/sadm/bin:$PATH LATER_MSG="PaTcH_MsG 6 ERROR: A later version of this patch is applied." NOPATCH_MSG="PaTcH_MsG 2 ERROR: Patch number $ACTIVE_PATCH is not installed" NEW_LIST="" # Get OLDLIST . $1 # # Confirm that the patch that got us here is the latest one installed on # the system and remove it from PATCHLIST. # Is_Inst=0 Skip=0 active_base=`echo $ACTIVE_PATCH | nawk ' { print substr($0, 1, match($0, "Patchvers_pfx")-1) } '` active_inst=`echo $ACTIVE_PATCH | nawk ' { print substr($0, match($0, "Patchvers_pfx")+1) } '` for patchappl in ${OLDLIST}; do appl_base=`echo $patchappl | nawk ' { print substr($0, 1, match($0, "Patchvers_pfx")-1) } '` if [ $appl_base = $active_base ]; then appl_inst=`echo $patchappl | nawk ' { print substr($0, match($0, "Patchvers_pfx")+1) } '` result=`expr $appl_inst \> $active_inst` if [ $result -eq 1 ]; then puttext "$LATER_MSG" exit 3 elif [ $appl_inst = $active_inst ]; then Is_Inst=1 Skip=1 fi fi if [ $Skip = 1 ]; then Skip=0 else NEW_LIST="${NEW_LIST} $patchappl" fi done if [ $Is_Inst = 0 ]; then puttext "$NOPATCH_MSG" exit 3 fi # # OK, all's well. Now condition the key variables. # echo "PATCHLIST=${NEW_LIST}" >> $1 echo "Patch_label=" >> $1 echo "PATCH_INFO_$ACTIVE_PATCH=backed out" >> $1 # Get the current PATCH_OBSOLETES and condition it Old_Obsoletes=$PATCH_OBSOLETES echo $ACTIVE_OBSOLETES | sed 'y/\ /\n/' | \ nawk -v PatchObsList="$Old_Obsoletes" ' BEGIN { printf("PATCH_OBSOLETES="); PatchCount=split(PatchObsList, PatchObsComp, " "); for(PatchIndex in PatchObsComp) { Atisat=match(PatchObsComp[PatchIndex], "@"); PatchObs[PatchIndex]=substr(PatchObsComp[PatchIndex], \ 0, Atisat-1); PatchObsCnt[PatchIndex]=substr(PatchObsComp\ [PatchIndex], Atisat+1); } } { for(PatchIndex in PatchObs) { if (PatchObs[PatchIndex] == $0) { PatchObsCnt[PatchIndex]=PatchObsCnt[PatchIndex]-1; } } next; } END { for(PatchIndex in PatchObs) { if ( PatchObsCnt[PatchIndex] > 0 ) { printf("%s@%d ", PatchObs[PatchIndex], PatchObsCnt\ [PatchIndex]); } } printf("\n"); } ' >> $1 # remove the used parameters echo "ACTIVE_OBSOLETES=" >> $1 echo "Obsoletes_label=" >> $1 exit 0 |
# This script deletes the used backout data for a patch package # and removes the deletes file entries. # # directory format options. # # @(#)patch_postinstall 1.2 96/01/29 SMI # # Copyright (c) 1995 by Sun Microsystems, Inc. # All rights reserved # PATH=/usr/sadm/bin:$PATH THIS_DIR=`dirname $0` Our_Deletes=$THIS_DIR/deletes # # Delete the used backout data # if [ -f $Our_Deletes ]; then cat $Our_Deletes | while read path; do if valpath -l $path; then Client_Path=`echo "$CLIENT_BASEDIR/$path" | sed s@//@/@` else # It's an absolute path Client_Path=$path fi rm `removef $PKGINST $Client_Path` done removef -f $PKGINST rm $Our_Deletes fi # # Remove the deletes file, checkinstall and the postinstall # rm -r $PKGSAV/$ACTIVE_PATCH rm -f $THIS_DIR/checkinstall $THIS_DIR/postinstall exit 0 |
