Solaris Volume Manager Administration Guide
Reserving a Disk Set
Before a host can use drives in a disk set, the host must reserve the disk set. There are two methods of reserving a disk set:
Note –
If a drive has been determined unexpectedly not to be reserved (perhaps because another host using the disk set forcibly took the drive), the host will panic. This behavior helps to minimize data loss which would occur if two hosts were to simultaneously access the same drive.
For more information about taking or reserving a disk set, see How to Take a Disk Set.
