# metainit d45 -r c2t3d0s2 c3t0d0s2 c4t0d0s2 d45: RAID is setup |
In this example, the RAID 5 volume d45 is created with the -r option from three slices. Because no interlace value is specified, d45 uses the default of 16 Kbytes. The system verifies that the RAID 5 volume has been set up, and begins initializing the volume.
You must wait for the initialization to finish before you can use the RAID 5 volume.
