# metastat d10 d10: Trans State: Okay Size: 102816 blocks Master Device: d0 Logging Device: d1 d0: Mirror Submirror 0: d11 State: Okay ... Submirror 1: d12 State: Okay ... # metattach d11 c0t2d0s5 d11: component is attached # metattach d12 c0t3d0s5 d12: component is attached |
This example shows the expansion of a transactional device, d10, whose master device consists of a two-way RAID 1 volume, d0, which contains two submirrors, d11 and d12. The metattach command is run on each submirror. The system confirms that each slice was attached.
