Task |
Description |
For Instructions |
Replace a failed slice |
If a disk fails, you must replace the slices used in your Solaris Volume Manager configuration. In the case of RAID 0 volume, you have to use a new slice, delete and recreate the volume, then restore data from a backup. Slices in RAID 1 and RAID 5 volumes can be replaced and resynchronized without loss of data. | ||
Recover from boot problems |
Special problems can arise when booting the system, due to a hardware problem or operator error. |
How to Recover From Improper /etc/vfstab Entries |
Work with transactional volume problems |
Problems with transactional volumes can occur on either the master or logging device, and they can either be caused by data or device problems. All transactional volumes sharing the same logging device must be fixed before they return to a usable state. |
