System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Configuring PAM
You can configure pam_ldap with or without password management support. Choose the appropriate procedure for your configuration from the following two options.
Using pam_ldap Without Password Management Support
If you are using pam_ldap without password management support, follow the sample pam.conf file in Example pam.conf File for pam_ldap. Add the lines that contain pam_ldap.so.1 to the client's /etc/pam.conf file. For details, see pam.conf(4).
Configuring pam_ldap for Password Management Support
If you need to configure pam_ldap for password management support, copy the sample pam.conf file in Example pam_conf file for pam_ldap Configured for Password Management. Then, add the lines that contain pam_ldap.so.1 to the client's /etc/pam.conf file. In addition, if any PAM module in the sample pam.conf file specifies the binding control flag and the server_policy option, use the same flag and option for the corresponding module in the client's /etc/pam.conf file. Also, add the server_policy option to the line that contains the service module pam_authtok_store.so.1.
