System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
The serial Field
This field is the version number of this data file. You must increment this number whenever you make a change to the data: slave servers use the serial field to detect whether the data file has been changed since the last time they copied the file from the master server.
