You can configure Sun ONE Directory Server software using one of the three different configuration methods supported by the configuration program.
Express configuration
Use this method if you are installing for the purposes of evaluating or testing Sun ONE Directory Server.
Typical configuration
Use this method if you are performing a normal install of Sun ONE Directory Server.
Custom configuration
In Sun ONE Directory Server, the custom configuration process is very similar to the typical configuration process. The main difference is that the custom configuration process allows you to import an LDIF file to initialize the user directory database that is created by default.
