Many Sun ONE servers, including Sun ONE Directory Server, use an instance of Sun ONE Directory Server to store configuration information. This information is stored in the o=NetscapeRoot directory tree. This directory tree does not need to be held on the same Sun ONE Directory Server as your directory data. Your configuration directory is the Sun ONE Directory Server that contains the o=NetscapeRoot.
If you are installing Sun ONE Directory Server only to support other Sun ONE servers, then that Sun ONE Directory Server is your configuration directory. If you are installing Sun ONE Directory Server to use as part of a general directory service, then you will have multiple instances of Sun ONE Directory Server installed in your organization and you must decide which one will host the configuration directory tree, o=NetscapeRoot. You must make this decision before you install any Sun ONE servers (including Sun ONE Directory Server).
For ease of upgrades, you should use a Sun ONE Directory Server instance that is dedicated to supporting the o=NetscapeRoot tree; this server instance should perform no other function with regard to managing your enterprise's directory data. Also, do not use port 389 for this server instance because doing so could prevent you from installing a Sun ONE Directory Server on that host that can be used for management of your organization's directory data.
Because the configuration directory normally experiences very little traffic, you can allow its server instance to coexist on a machine with another more heavily loaded Sun ONE Directory Server instance. However, for very large sites that are installing a large number of Sun ONE servers, you may want to dedicate a low-end machine to the configuration directory so as to not hurt the performance of production servers. Sun ONE server configurations result in write activities to the configuration directory. For large enough sites, this write activity could result in a short-term performance hit to your other directory activities.
Also, as with any directory configuration, consider replicating the configuration directory to increase availability and reliability. For information about using replication to increase directory availability, refer to the deployment guide for the version of Sun ONE Directory Server that you are using.
If the configuration directory tree is corrupted, you might need to reinstall all other Sun ONE servers that are registered in that configuration directory. Remember the following guidelines when dealing with the configuration directory.
Always back up your configuration directory after you install a new Sun ONE server.
Never change the host name or port number used by the configuration directory.
Never directly modify the configuration directory tree. Only the setup program for the various Sun ONE servers should ever modify the configuration.
