During the server installation process, you will have defined crucial variables, with which you should create a checklist similar to the one below before launching idsconfig. You can use the blank checklist provided in Blank Checklists.
The information included below will serve as the basis for all examples that follow in the LDAP related chapters. The example domain is of an widget company, Example, Inc. with stores nationwide. The examples will deal with the West Coast Division, with the domain west.example.com
Variable |
Definition for Example Network |
Port number at which an instance of the directory server is installed (DEFAULT=389) |
default |
Name of server |
myserver (from the FQDN ipdserver.west.example.com or 192.168.0.0) |
Replica server(s) (IPnumber:port number) |
192.168.0.1 [for ipdrep.west.example.com] |
Directory manager [dn: cn=directory manager] |
default |
Domain name to be served |
west.example.com |
Maximum time (in seconds) to process client requests before timing out |
—1 |
Maximum number of entries returned for each search request |
—1 |
If you are using hostnames in defining defaultServerList or preferredServerList, you MUST ensure LDAP is not used for hosts lookup. This means ldap must not be in /etc/nsswitch.conf hosts line.
Client profiles are defined per domain. At least one profile must be defined for a given domain.
idsconfig indexes the following list of attributes for improved performance.
pres,eq,sub
pres,eq,sub
pres,eq
pres,eq
pres,eq
pres,eq
pres,eq
pres,eq
pres,eq
