The certdb subcommand manages the publickey database. Options to the subcommand enable you to add, view, and remove certificates and public keys. The command accepts, as input, certificates that were generated by the ikecert certlocal –ks command on a remote system. See How to Configure IKE With Self-Signed Public Key Certificates for the procedure. This command also accepts the certificate that you receive from a PKI or CA as input. See How to Configure IKE With Certificates Signed by a CA for the procedure.
On the system, the certificates and public keys are stored in the /etc/inet/ike/publickeys directory. The -T option stores the certificates, private keys, and public keys on attached hardware.
