The Phase 1 exchange is known as Main Mode. In the Phase 1 exchange, IKE uses public key encryption methods to authenticate itself with peer IKE entities. The result is an ISAKMP (Internet Security Association and Key Management Protocol) security association (SA). An ISAKMP SA is a secure channel for IKE to negotiate keying material for the IP datagrams. Unlike IPsec SAs, the ISAKMP SAs are bidirectional, so only one security association is needed.
How IKE negotiates keying material in the Phase 1 exchange is configurable. IKE reads the configuration information from the /etc/inet/ike/config file. Configuration information includes the following:
Global parameters, such as the names of public key certificates
If perfect forward secrecy (PFS) is used
The interfaces that are affected
The algorithms that are used
The authentication method
The two authentication methods are preshared keys and public key certificates. The public key certificates can be self-signed, or the certificates can be issued by a certificate authority (CA) from a PKI (public key infrastructure) organization. Organizations include Baltimore Technologies, Entrust, GeoTrust, RSA Security, Sun Open Net Environment (Sun ONE) Certificate Server, and Verisign.
