Secure traffic between two systems
Involves:
Adding addresses to the /etc/inet/ipnodes file
Entering the IPsec policy in the /etc/inet/ipsecinit.conf file
Setting up key exchange
Activating the ipsecinit.conf file
How to Secure Traffic Between Two Systems
Secure a web server by using IPsec policy
Involves enabling only secure traffic by entering different security requirements for different ports in the ipsecinit.conf file. Also involves activating the file.
How to Secure a Web Server
Set up a virtual private network (VPN)
Involves:
Turning off IP forwarding
Turning on IP strict destination multihoming
Disabling most network and Internet services
Adding security associations
Configuring the IPsec policy
Configuring a secure tunnel
Turning on IP forwarding
Configuring a default route
Running the routing protocol
How to Set Up a Virtual Private Network (VPN)
Generate random numbers
Involves using the od command to generate random numbers for keying material when you manually create SAs.
How to Generate Random Numbers
Create or replace security associations (SAs) manually
Involves using the ipseckey command to create SAs. Also involves creating an ipseckeys
file to hold the keying material.
How to Manually Create IPsec Security Associations
Check that IPsec is protecting the packets
Involves examining snoop output for specific headers that indicate how the IP datagrams are protected.
How to Verify That Packets Are Protected
