Solaris 9 12/03 Installation Guide
Merging a Solaris Flash Archive
After you have split an archive into sections, you can combine the sections to create a new archive.
The flar combine command creates a Solaris Flash archive from individual sections. Each section is assumed to be in a separate file, the names of which are the section names. At a minimum, these three files must be present:
When combining sections, remember the following points:
flar combine [-d dir] [-u section] [-t [-p posn] [-b blocksize]] filename
-d dir
Retrieves the sections to combine from dir, rather than from the current directory.
-u section
  • If you use this option, flar copies the Cookie, Identification, Archive, and section sections. You can specify a single section name or a space-separated list of section names.
  • If you do not use this option, flar copies the Cookie, Identification, and Archive sections only.
Example 19–2 Merging a Solaris Flash Archive
In this example, an Archive Cookie section, an Archive Identification section, and an Archive Files section are combined to become a complete archive. The archive is named newarchive.flar.
# flar combine newarchive.flar
Example 19–3 Merging a Solaris Flash Archive and Adding a User-Defined Section
In this example, an Archive Cookie section, an Archive Identification section, an Archive Files section, and a User-Defined section are combined to become a complete archive. The archive is named newarchive.flar. The User-Defined section content is in the file that is named user-defined, which is in the current directory.
# flar combine -u user_defined newarchive.flar
