Solaris 9 12/03 Installation Guide
Guidelines for Selecting Slices for Mirrored File Systems
You can create a new boot environment that contains any combination of physical disk slices, Solaris Volume Manager volumes, or Veritas Volume Manager volumes. Critical file systems that are copied to the new boot environment can be of the following types:
When you create a new boot environment, the lucreate -m command recognizes the following three types of devices:
Note –
If you have problems upgrading with Veritas VxVM, see System Panics When Upgrading With Solaris Live Upgrade Running Veritas VxVm.
General Guidelines for Creating Mirrored File Systems
Specifying a Volume
You can choose to specify a mirror or submirror or allow the lucreate command to choose a free volume for you.
Volume Naming Shortcuts
You can abbreviate the names of physical disk slices and Solaris Volume Manager volumes. The abbreviation is the shortest name that uniquely identifies a device. Examples follow.
For more information on naming requirements and guidelines, see “Overview of Solaris Volume Manager Components” in Solaris Volume Manager Administration Guide.
Checking Status of Volumes
If a mirror or submirror needs maintenance or is busy, components cannot be detached. You should use the metastat command before creating a new boot environment and using the detach keyword. The metastat command checks if the mirror is in the process of resynchronization or if the mirror is in use. For information, see the man page metastat(1M).
Detaching Volumes and Resynchronizing Mirrors
If you use the detach keyword to detach a submirror, lucreate checks if a device is currently resyncing. If the device is resyncing, you cannot detach the submirror and you get an error message.
Resynchronization is the process of copying data from one submirror to another submirror after the following problems:
For more information about resynchronization, see “RAID 1 Volume (Mirror) Resynchronization” in Solaris Volume Manager Administration Guide.
Using Solaris Volume Manager Commands
Use the lucreate command rather than Solaris Volume Manager commands to manipulate volumes on inactive boot environments. The Solaris Volume Manager software has no knowledge of boot environments, whereas the lucreate command contains checks that prevent you from inadvertently destroying a boot environment. For example, lucreate prevents you from overwriting or deleting a Solaris Volume Manager volume.
However, if you have already used Solaris Volume Manager software to create complex Solaris Volume Manager concatenations, stripes, and mirrors, you must use Solaris Volume Manager software to manipulate them. Solaris Live Upgrade is aware of these components and supports their use. Before using Solaris Volume Manager commands that can create, modify, or destroy volume components, use the lustatus or lufslist commands. These commands can determine which Solaris Volume Manager volumes contain file systems that are in use by a Solaris Live Upgrade boot environment.
