Solaris 9 12/03 Installation Guide
Solaris Live Upgrade Disk Space Requirements
Follow general disk space requirements for an upgrade. See Chapter 5, System Requirements and Guidelines (Planning).
To estimate the file system size that is needed to create a boot environment, start the creation of a new boot environment. The size is calculated. You can then abort the process.
The disk on the new boot environment must be able to serve as a boot device. Some systems restrict which disks can serve as a boot device. Refer to your system's documentation to determine if any boot restrictions apply.
The disk might need to be prepared before you create the new boot environment. Check to make sure the disk is formatted properly:
