Solaris 9 12/03 Installation Guide
Installing Keys on the Client
For a more secure WAN boot installation or an insecure installation with data integrity checking, you must install keys on the client. By using a hashing key and an encryption key, you can protect the data that is transmitted to the client. You can install these keys in the following ways.
You can also install keys in the OBP of a running client. If you want to install keys on a running client, the system must be running the Solaris 9 12/03 operating environment, or compatible version.
When you install keys on your client, ensure that the key values are not transmitted over an insecure connection. Follow your site's security policies to ensure the privacy of the key values.
To Install Keys in the Client OBP
If you want to assign key values to OBP network boot argument variables, follow these steps.
  1. Assume the same user role as the web server user on the WAN boot server.
  2. Display the key value for each client key.
    # wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=key-type
    net-ip
    The IP address of the client's subnet.
    client-ID
    The ID of the client you want to install. The client ID can be a user-defined ID or the DHCP client ID.
    key-type
    The key type you want to install on the client. Valid key types are 3des, aes, or sha1.
    The hexadecimal value for the key is displayed.
  3. Repeat the previous step for each type of client key you want to install.
  4. Bring the client system to run level 0.
    # init 0
    The ok prompt is displayed.
  5. At the client ok prompt, set the value for the hashing key.
    ok set-security-key wanboot-hmac-sha1 key-value
    set-security-key
    Installs the key on the client
    wanboot-hmac-sha1
    Instructs OBP to install a HMAC SHA1 hashing key
    key-value
    Specifies the hexadecimal string that is displayed in Step 2.
    The HMAC SHA1 hashing key is installed in the client OBP.
  6. At the client ok prompt, install the encryption key.
    ok set-security-key wanboot-3des key-value
    set-security-key
    wanboot-3des
    Instructs OBP to install a 3DES encryption key. If you want to use an AES encryption key, set this value to wanboot-aes.
    key-value
    Specifies the hexadecimal string that represents the encryption key.
    The 3DES encryption key is installed in the client OBP.
    After you install the keys, you are ready to install the client. See Installing the Client for instructions about how to install the client system.
  7. (Optional) Verify that the keys are set in the client OBP.
    ok list-security-keys
    Security Keys:
             wanboot-hmac-sha1
             wanboot-3des
  8. (Optional) If you need to delete a key, type the following command.
    ok set-security-key key-type
    key-type
    Specifies the type of key you need to delete. Use the value wanboot-hmac-sha1, wanboot-3des, or wanboot-aes.
Example 41–3 Installing Keys in the Client OBP
The following example shows how to install a hashing key and an encryption key in the client OBP.
Display the key values on the WAN boot server.
# wanbootutil keygen -d -c -o net=192.168.198.0,cid=010003BA152A42,type=sha1
b482aaab82cb8d5631e16d51478c90079cc1d463
# wanbootutil keygen -d -c -o net=192.168.198.0,cid=010003BA152A42,type=3des
9ebc7a57f240e97c9b9401e9d3ae9b292943d3c143d07f04
The previous example uses the following information.
net=192.168.198.0
Specifies the IP address of the client's subnet
cid=010003BA152A42
Specifies the client's ID
Specifies the value of the client's HMAC SHA1 hashing key
Specifies the value of the client's 3DES encryption key
If you use an AES encryption key in your installation, change wanboot-3des to wanboot-aes to display the encryption key value.
Install the keys on the client system.
ok set-security-key wanboot-hmac-sha1 b482aaab82cb8d5631e16d51478c90079cc1d463
ok set-security-key wanboot-3des 9ebc7a57f240e97c9b9401e9d3ae9b292943d3c143d07f04
The previous commands perform the following tasks.
To Install a Hashing Key and an Encryption Key on a Running Client
If you want to install a hashing key and an encryption key in the OBP of a running client, follow these steps.
Note –
This procedure makes the following assumptions.
  2. Display the key value for the client keys.
    net-ip
    client-ID
    key-type
  4. Become superuser on the client machine.
  5. Install the necessary keys on the running client machine.
    # /usr/lib/inet/wanboot/ickey -o type=key-type
    > key-value
    key-type
    Specifies the key type you want to install on the client. Valid key types are 3des, aes, or sha1.
    key-value
  6. Repeat the previous step for each type of client key you want to install.
Example 41–4 Installing Keys in the OBP of a Running Client System
The following example shows how to install keys in the OBP of a running client.
net=192.168.198.0
cid=010003BA152A42
If you use an AES encryption key in your installation, change type=3des to type=aes to display the encryption key value.
Install the keys in the OBP of the running client.
# /usr/lib/inet/wanboot/ickey -o type=sha1 b482aaab82cb8d5631e16d51478c90079cc1d463
# /usr/lib/inet/wanboot/ickey -o type=3des 9ebc7a57f240e97c9b9401e9d3ae9b292943d3c143d07f04
