If you use the suninstall program to install the Solaris 9 12/03 Software from CD onto a system that has multiple CD-ROM drives, the Solaris 9 12/03 2 of 2 CD might not install correctly.
After the installation of the Solaris Software 1 of 2 CD completes, the system reboots. The installation program then prompts you to insert the 2 of 2 CD. After you insert the CD, the installation program does not mount the CD.
For SPARC systems, the following message is displayed repeatedly:
Please insert the CD/DVD for Solaris 9 Software 2 of 2 (12/03 SPARC Platform Edition) |
For x86 systems, the following message is displayed repeatedly:
Please insert the CD/DVD for Solaris 9 Software 2 of 2 (12/03 x86 Platform Edition) |
If your installation does not require software on the Solaris Software 2 of 2 CD, you do not encounter this error.
Workaround: Choose from the following workarounds:
Use the Solaris 9 12/03 Software DVD to perform the installation.
If you install the Solaris 9 12/03 Software from CD, follow these steps to avoid this problem:
When prompted by the installation program to install the Solaris Software 2 of 2 CD, select Skip.
The system will reboot again.
After the the system reboots, insert the Solaris Software 2 of 2 CD.
Open a terminal window.
Run the Solaris Software 2 of 2 installer.
# cd /cdrom/cdrom0# ./installer |
If prompted, answer the configuration questions.
