If you run the ufsdump command without any options, use this syntax:
# ufsdump filenames |
The ufsdump command uses these options and arguments, by default:
ufsdump 9uf /dev/rmt/0 filenames |
These options do a level 9 incremental backup to the default tape drive at its preferred density.
