System Administration Guide: Basic Administration
Example—Viewing the Working Set (Cache) Size
In the following example, the end size is the size of the cache at the time you issued the cachefswssize command. The high water size is the largest size of the cache during the time frame in which logging occurred.
# cachefswssize /var/tmp/samlog
    /home/sam
	       end size:  10688k
	high water size:  10704k
	       end size:   1736k
	high water size:   1736k
    /opt
	       end size:    128k
	high water size:    128k
    /nfs/saturn.dist
	       end size:   1472k
	high water size:   1472k
    /data/abc
	       end size:   7168k
	high water size:   7168k
    /nfs/venus.svr4
	       end size:   4688k
	high water size:   5000k
    /data
	       end size:   4992k
	high water size:   4992k
    total for cache
	   initial size: 110960k
	       end size:  30872k
	high water size:  30872k
