Use the following error messages and solutions to troubleshoot problems with multiterabyte UFS file systems.
mount: /dev/rdsk/c0t0d0s0 is not this fstype. |
You attempted to mount a UFS file system that is greater than 1 terabyte on a system running a Solaris release prior to the Solaris 9 8/03 release.
Mount a UFS file system that is greater than 1 terabyte on a system running the Solaris 9 8/03 or later release.
"File system was not set up with the multi-terabyte format." "Its size cannot be increased to a terabyte or more." |
You attempted to expand a file system that was not created with the newfs -T command.
Back up the data for the file system that you want to expand to greater than one terabyte.
Re-create the file system with the newfs command to create a multiterabyte file system or use the newfs -T command if the file system will be grown to a multiterabyte file system over time.
Restore the backup data into the newly created file system.
