System Administration Guide: Basic Administration
How to Expand a Multiterabyte UFS File System
After a multiterabyte UFS file system is created, you can use the growfs command to expand the file system. For example, using the file system that was created for the volume in the preceding procedure, you can add another disk to this volume. Then, expand the file system.
  1. Become superuser.
  2. Add another disk to the volume.
    For example:
    # metattach d99 c4t5d0s4
    d99: component is attached
    # metastat
    d99: Concat/Stripe
        Size: 5145882624 blocks (2.4 TB)
        Stripe 0:
            Device     Start Block  Dbase   Reloc
            c0t1d0s4      36864     Yes     Yes
        Stripe 1:
            c3t7d0s4          0     No      Yes
        Stripe 2:
            c1t1d0s4          0     No      Yes
        Stripe 3:
            c4t5d0s4          0     No      Yes
  3. Expand the file system.
    For example:
    # growfs -v /dev/md/rdsk/d99
    /usr/lib/fs/ufs/mkfs -G /dev/md/rdsk/d99 5145882624
    /dev/md/rdsk/d99:    5145882624 sectors in 837546 cylinders of 48 tracks,
    128 sectors
            2512638.0MB in 5857 cyl groups (143 c/g, 429.00MB/g, 448 i/g)
    super-block backups (for fsck -F ufs -o b=#) at:
     32, 878752, 1757472, 2636192, 3514912, 4393632, 5272352, 6151072, 702...
    Initializing cylinder groups:
    super-block backups for last 10 cylinder groups at:
     5137130400, 5138009120, 5138887840, 5139766560, 5140645280, 5141524000,
     5142402720, 5143281440, 5144160160, 5145038880,
  4. Mount and verify the expanded file system.
    For example:
    # mount /dev/md/dsk/d99 /bigdir
    # df -h /bigdir
    Filesystem             size   used  avail capacity  Mounted on
    /dev/md/dsk/d99        2.4T    64M   2.4T     1%    /bigdir
