After you have installed a patch management tool, you can use several different methods of downloading or adding a signed patch or patches to your system. Use the following table to determine which method is best for your needs.
Command or Tool |
Description |
For More Information |
patchadd |
Solaris 9 12/03 release only – – Use this command to add signed patches to your system after your have set up your package keystore. |
patchadd(1m) |
smpatch update |
Use this command to identify required patches, and then, automatically download and add the patches to your system. | |
smpatch analyze |
Use this command to identify required patches and display a list of required patch IDs for your system. Then, you could use the smpatch download and smpatch add commands to download and add the patches to your system. |
smpatch(1M) |
smpatch download and smpatch add |
Use these commands to download and add a patch or patches to your system. These commands also download and add any prerequisite patches. | |
ftp and smpatch add |
Use the ftp command to transfer a patch or patches to your system. Then, use the smpatch add command to add the patch or patches to your system. | |
Solaris Management Console Patches Tool |
For Solaris 9 systems only – Use this tool when you want the convenience of a GUI tool to manage signed patches. |
Solaris Management Console online help |
