This table provides a brief overview of the Solaris Schema files in /usr/sadm/mof.
Table A–1 Solaris Schema Files| Solaris Schema File | What This Schema File Provides |
| Solaris_Acl.mof |
Contains the classes for WBEM access control list (ACL) based security. |
| Solaris_Application.mof |
Models Solaris packages and patches in CIM. |
| Solaris_CIMOM.mof |
Contains configuration information for the CIM Object Manager. |
| Solaris_Core.mof |
Contains class definition for core classes including the computer system and statistical information. |
| Solaris_Device.mof |
Enables a description of your system's processor, serial ports, printing devices, and time settings to make your computer work with the CIM Object Manager. |
| Solaris_Event.mof |
Defines unique Solaris indication handlers. The class that is defined in this file facilitates the delivery of indications to Management clients. The protocol that is used for this delivery is the implementation of the CIM Remote Method Invocation (RMI) protocol from Sun Microsystems. |
| Solaris_Network.mof |
Defines classes pertaining to network domains, IP subnets, and naming services including NIS, NIS+, LDAP, DNS, and server /etc files. |
| Solaris_Performance.mof |
Defines classes that pertain to the use and performance of computing resources for each user and for each project. |
| Solaris_Project.mof |
Defines classes that model the Solaris project database. |
| Solaris_Schema.mof |
Lists all of the MOF files of the Solaris Schema, and specifies the order in which the MOF files are read and are compiled. |
| Solaris_SNMP.mof |
Contains classes used to configure the SNMP provider and its communication to SNMP agents on different systems. |
| Solaris_System.mof |
Models the Solaris Schema components for a system, including the operating system and processes of the system. |
| Solaris_Users.mof |
Defines classes for working with user accounts. |
| Solaris_VM1.0.mof |
Defines classes that pertain to storage devices. |
| WBEMServices.mof |
Contains classes to configure the class path of the CIM object manager and its protocol adapters, both for clients and providers. |
The following sections describe the contents of each schema file in more detail.
The Solaris_Acl.mof file specifies the security classes in Solaris WBEM Services. This file defines these base classes for access control lists, users, and namespaces:
Solaris_Acl
Solaris_NamespaceAcl
Solaris_UserAcl
The Solaris_Application.mof file enables you to set up packages and patches for your applications that extend the Solaris Schema. The Solaris_Application.mof file defines the following classes:
Solaris_InstalledSoftwareElement
Solaris_Package
Solaris_Patch
Solaris_RegistrySoftwareElement
Solaris_SoftwareElement
Solaris_SoftwareFeature
In addition, the Solaris_Application.mof file defines the following association classes:
Solaris_PatchPackageDependency
Solaris_PatchToPatchDependency
Solaris_ProductSoftwareElementDependency
Solaris_ProductSoftwareElements
Solaris_ProductSoftwareFeatureDependency
Solaris_ProductSoftwareFeatures
Solaris_RegistryElementDependency
Solaris_SoftwareElementDependency
Solaris_SoftwareElementProductDependency
Solaris_SoftwareElementSoftwareFeatureDependency
Solaris_SoftwareFeatureDependency
Solaris_SoftwareFeatureParentChild
Solaris_SoftwareFeatureProductDependency
Solaris_SoftwareFeatureSoftwareElementDependency
Solaris_SoftwareFeatureSoftwareElements
The Solaris_CIMOM.mof file contains all the system properties used by the CIM Object Manager. The Solaris_CIMOM.mof file defines the following classes:
CIM_ObjectManager
CIM_ObjectManagerCommunicationMechanism
CIM_WBEMCommunicationMechanism
Solaris_CIMOM
Solaris_ObjectManagerClientProtocolAdapter
Solaris_ObjectManagerProtocolAdapter
Solaris_ObjectManagerProviderProtocolAdapter
Solaris_ProviderPath
In addition, the Solaris_CIMOM.mof file defines the association class CIM_CommMechanismForManager.
The Solaris_Core.mof file is the first of the Solaris Schema files to be compiled after the Solaris_Schema.mof file. This file provides the definition of the Solaris_ComputerSystem class of the Solaris provider. The Solaris_Core.mof file defines the following classes:
Solaris_LogRecord
Solaris_LogService
Solaris_Product
Solaris_SystemDownStatisticalInformation
Solaris_SystemUpStatisticalInformation
The Solaris_LogRecord class and the Solaris_LogService class have been deprecated. Refer to the class description to determine a suitable alternative.
In addition, the Solaris_Core.mof file defines the following association classes:
Solaris_ProductParentChild
Solaris_ProductProductDependency
Solaris_SystemSetting
The Solaris_Device.mof file defines the following classes:
Solaris_Environment
Solaris_EthernetAdapter
Solaris_Keyboard
Solaris_LogEntry
Solaris_LogServiceProperties
Solaris_LogServiceSetting
Solaris_MessageLog
Solaris_MessageLogRecord
Solaris_MessageLogSetting
Solaris_Printer
Solaris_PrintJob
Solaris_PrintQueue
Solaris_PrintSAP
Solaris_PrintService
Solaris_Processor
Solaris_SerialPort
Solaris_SerialPortConfiguration
Solaris_SerialPortSetting
Solaris_SoundDevice
Solaris_SyslogRecord
Solaris_TimeZone
The Solaris_LogServiceSetting class and the Solaris_LogServiceLogServiceProperties class have been deprecated. Refer to the class description to determine a suitable alternative.
In addition, the Solaris_Device.mof file defines the following association classes:
Solaris_CpuSysinfoPerformanceMonitor
Solaris_CpuUtilizationPerformanceMonitor
Solaris_CpuVminfoPerformanceMonitor
Solaris_LogInDataFile
Solaris_OwningPrintQueue
Solaris_PrinterServicingQueue
Solaris_QueueForPrintService
Solaris_RecordInLog
Solaris_SystemTimeZone
The Solaris_Event.mof file contains classes that deal with indication handlers that are unique to the Solaris platform. These Solaris indication handlers are subclasses of CIM_IndicationHandler. These subclasses include Solaris_RMIDelivery and Solaris_JAVAXRMIDelivery. The client RMI protocol uses the Solaris_JAVAXRMIDelivery handler. Solaris_Event.mof contains Solaris_RMIDelivery to ensure compatibility with previous versions of WBEM.
The Solaris_Network.mof file defines classes that pertain to network domains, IP subnets, and naming services. These naming services include NIS, NIS+, LDAP, DNS, and server /etc files. The Solaris_Network.mof file defines the following classes:
Solaris_AdminDomain
Solaris_DnsAdminDomain
Solaris_IPProtocolEndpoint
Solaris_IPSubnet
Solaris_LdapAdminDomain
Solaris_NisAdminDomain
Solaris_NisplusAdminDomain
Solaris_SystemAdminDomain
The OptionsEnabledproperty in the Solaris_IPProtocolEndpoint class has been deprecated. Refer to the class description to determine a suitable alternative.
The Solaris_Performance.mof file defines classes that pertain to computing resource metrics. These classes pertain to the use and performance of computing resources for each user and for each project. The Solaris_Performance.mof file defines the following classes:
Solaris_ActiveProject
Solaris_ActiveUser
Solaris_ProcessStatisticalInformation
Solaris_ProjectProcessAggregateStatisticalInformation
Solaris_UserProcessAggregateStatisticalInformation
In addition, the Solaris_Performance.mof file defines the following association classes:
Solaris_ActiveProjectProcessAggregateStatistics
Solaris_ActiveUserProcessAggregateStatistics
Solaris_ProcessStatistics
Solaris_ProjectProcessStatistics
Solaris_UserProcessStatistics
The Solaris_Project.mof file defines classes that represent the Solaris project database. The Solaris_Project.mof file defines the class Solaris_Project. In addition, the Solaris_Project.mof file defines the association classes Solaris_ProjectGroup and Solaris_ProjectUser.
The Solaris_Schema.mof file is the high-level container of all other MOF files that make up the Solaris Schema. This file lists the MOF files in the order in which the files must be compiled.
The Java classes that you generate from each compilation are then sent to the CIMOM. At the CIMOM, the classes are either enacted as events or sent to the CIM Object Manager Repository for storage as objects. The following listing of the Solaris_Schema.mof file shows the Include statements in the order that is required for compilation.
Solaris Schema
Copyright (c) 2002 Sun Microsystems, Inc. All Rights Reserved.
#pragma Include ("Solaris_Core.mof")
#pragma Include ("Solaris_Application.mof")
#pragma Include ("Solaris_System.mof")
#pragma Include ("Solaris_Device.mof")
#pragma Include ("Solaris_Network.mof")
#pragma Include ("Solaris_Users.mof")
#pragma Include ("Solaris_Project.mof")
#pragma Include ("Solaris_Event.mof")
#pragma Include ("Solaris_CIMOM.mof")
#pragma Include ("Solaris_SNMP.mof")
// This must be the last include since it changes the CIM namespace
#pragma Include ("Solaris_Acl.mof")
The compiler parses a line of the Solaris_Schema.mof file, compiles the file specified in the Include statement, and then parses the next line of the Solaris_Schema.mof file. This process continues until all included files are compiled.
The Solaris_SNMP.mof file defines classes that pertain to configuration information for an SNMP device. The Solaris_SNMP.mof file defines the following classes:
Solaris_SNMPGroupConf
Solaris_SNMPSystem
Solaris_SNMPSystemConf
The Solaris_System.mof file defines the following classes:
Solaris_CpuSysinfo
Solaris_CpuUtilizationInformation
Solaris_CpuVminfo
Solaris_DataFile
Solaris_DiskIOInformation
Solaris_DisklessClient
Solaris_Eeprom
Solaris_EepromSetting
Solaris_InstalledOS
Solaris_JobScheduler
Solaris_JobScheduler_Cron
Solaris_OperatingSystem
Solaris_OSProcess
Solaris_OsService
Solaris_Process
Solaris_RunningOS
Solaris_ScheduledJob
Solaris_ScheduledJob_Cron
In addition, the Solaris_System.mof file defines the following association classes:
Solaris_EepromElementSetting
Solaris_HostedJobScheduler
Solaris_OwningJobScheduler
Solaris_SystemDevice
The Solaris_Users.mof file defines the following classes:
Solaris_AuthorizationAttribute
Solaris_EmailAlias
Solaris_ExecutionProfile
Solaris_MailBox
Solaris_ProfileAttribute
Solaris_ShellSAP
Solaris_UserAccount
Solaris_UserGroup
Solaris_UserHomeDirectory
Solaris_UserTemplate
The Solaris_VM1.0.mof file defines classes that pertain to storage devices, for example:
State database replicas within a slice
Range of extents within a storage extent that can be used for data
Stripes
Concatenated stripes
Mirrors
RAID Level 5 devices
UFS logging file systems
Spare pools
Disk sets
Storage volumes
The Solaris_VM1.0.mof file defines the following classes:
Solaris_Directory
Solaris_DiskDrive
Solaris_DiskPartition
Solaris_HSFS
Solaris_LocalFileSystem
Solaris_MediaPresent
Solaris_NFS
Solaris_UFS
Solaris_VMConcat
Solaris_VMDiskSet
Solaris_VMExtent
Solaris_VMHotSparePool
Solaris_VMMirror
Solaris_VMRaid5
Solaris_VMSoftPartition
Solaris_VMStateDatabase
Solaris_VMStorageVolume
Solaris_VMStripe
Solaris_VMTrans
In addition, the Solaris_VM1.0.mof file defines the following association classes:
Solaris_DiskIOPerformanceMonitor
Solaris_HSFSMount
Solaris_LocalFSResidesOnExtent
Solaris_Mount
Solaris_NFSExport
Solaris_NFSMount
Solaris_UFSMount
Solaris_VMConcatComponent
Solaris_VMDriveInDiskSet
Solaris_VMExtentBasedOn
Solaris_VMExtentInDiskSet
Solaris_VMHostInDiskSet
Solaris_VMHotSpareInUse
Solaris_VMHotSpares
Solaris_VMMirrorSubmirrors
Solaris_VMRaid5Component
Solaris_VMSoftPartComponent
Solaris_VMStatistics
Solaris_VMStripeComponent
Solaris_VMTransLog
Solaris_VMTransMaster
Solaris_VMUsesHotSparePool
Solaris_VMVolumeBasedOn
The WBEMServices.mof file contains classes to configure the class path of the CIM object manager and its protocol adapters, both for clients and providers. The WBEMServices.mof file defines the following classes:
WBEMServices_CIMXMLObjectManagerClientProtocolAdapter
WBEMServices_Classpath
WBEMServices_ClientProtocolAdapterForManager
WBEMServices_ObjectManager
WBEMServices_ObjectManagerClientProtocolAdapter
WBEMServices_ObjectManagerProtocolAdapter
WBEMServices_ObjectManagerProviderProtocolAdapter
WBEMServices_ProtocolAdapterForManager
WBEMServices_ProviderProtocolAdapterForManager
WBEMServices_RMIObjectManagerClientProtocolAdapter
