You can set access control on a per-user basis or namespace basis. The following access control classes are stored in the root\security namespace:
Solaris_Acl – Base class for Solaris access control lists (ACLs). This class defines the string property capability and sets its default value to r (read only).
Solaris_UserAcl – Represents a user's access control to the CIM objects within the specified namespace.
Solaris_NamespaceAcl – Represents the access control on a namespace.
You can set access control for individual users to CIM objects within a namespace. Create an instance of the Solaris_UserACL class and then change the access rights for that instance. Similarly, you can set access control for a namespace by creating an instance of the Solaris_NameSpaceACL class and then using the createInstance method to set the access rights for that instance.
Combine the use of these two classes by using the Solaris_NameSpaceACL class to first restrict access for all users to the objects in a namespace. Then, you can use the Solaris_UserACL class to grant selected users access to the namespace.
The Solaris_UserAcl class extends the Solaris_Acl base class, from which it inherits the string property capability with a default value of r (read only). You can set the capability property to any one of the values for access privileges shown in the following table.
Access Right |
Description |
r |
Read |
rw |
Read and Write |
w |
Write |
none |
No access |
The Solaris_UserAcl class defines the key properties that are shown in the following table. Only one instance of the namespace and user name ACL pair can exist in a namespace.
Property |
Data Type |
Purpose |
nspace |
string |
Identifies the namespace to which the ACL applies |
username |
string |
Identifies the user to which the ACL applies |
Create an instance of the Solaris_UserAcl class.
/* Create a namespace object initialized with root\security
(name of namespace) on the local host. */
CIMNameSpace cns = new CIMNameSpace("", "root\security");
// Connect to the root\security namespace as root.
cc = new CIMClient(cns, user, user_passwd);
// Get the Solaris_UserAcl class
cimclass = cc.getClass(new CIMObjectPath("Solaris_UserAcl");
// Create a new instance of the Solaris_UserAcl
class ci = cimclass.newInstance();
Set the capability property to the desired access rights.
/* Change the access rights (capability) to read/write for user Guest
on objects in the root\molly namespace.*/
ci.setProperty("capability", new CIMValue(new String("rw"));
ci.setProperty("nspace", new CIMValue(new String("root\molly"));
ci.setProperty("username", new CIMValue(new String("guest"));
... // Pass the updated instance to the CIM Object Manager cc.createInstance(new CIMObjectPath(), ci); ...
The Solaris_NamespaceAcl extends the Solaris_Acl base class and inherits the string property capability with a default value r (read-only for all users). The Solaris_NamespaceAcl class defines this key property.
Property |
Data Type |
Purpose |
nspace |
string |
Identifies the namespace to which the access control list applies. Only one instance of the namespace ACL can exist in a namespace. |
Create an instance of the Solaris_namespaceAcl class.
// Get the Solaris_namespaceAcl class
cimclass = cc.getClass(new CIMObjectPath("Solaris_namespaceAcl");
// Create a new instance of the Solaris_namespaceAcl
to the root\molly namespace. */
