Method |
No args |
deep |
localOnly |
enumerateClasses |
Returns the contents of the class specified in path. |
If true: Returns the contents of the subclasses of the specified class, but does not return the class. |
If true: Returns only noninherited properties and methods of the specified class. |
If false: Returns the contents of the direct subclasses of the specified class. |
If false: Returns all properties of the specified class. |
enumerateInstances |
Returns the instances of the class specified in path. |
If true: Returns the instances of the specified class and its subclasseses. |
If true: Returns only noninherited properties of the instances of the specified class. |
If false: Returns the instances of the specified class and its subclasses. The properties of the subclasses are filtered out. |
If false: Returns all properties of the instances of the specified class. |
enumerateClassNames |
Returns the names of the class specified in path. |
If true: Returns the names of all classes derived from the specified class. |
N/A |
If false: Returns only the names of the first-level children of the specified class. |
N/A |
enumerateInstanceNames |
Returns the names of the instances of the class specified in path. |
N/A |
N/A |
enumNameSpace |
Returns a list of the namespaces within the namespace specified in path |
If true: Returns the entire hierarchy of namespaces under the specified namespace. |
N/A |
If false: Returns only the first level children of the specified namespace. |
N/A |
The following example program returns the contents of a class and its subclasses.
/* Creates a CIMObjectPath object and initializes it
with the name of the CIM class to be enumerated (myclass). */
CIMObjectPath cop = new CIMObjectPath(myclass);
/* This enumeration contains the classes and subclasses
in the enumerated class (deep=true). This enumeration
returns only the noninherited methods and properties
for each class and subclass (localOnly is true).*/
Enumeration e = cc.enumerateClasses(cop, true, true);
The following example program performs a deep and shallow (deep=false) enumeration of classes and instances. The localOnly flag returns the contents of the classes and instances instead of the names of the classes and instances.
import java.rmi.*;
import java.util.Enumeration;
import javax.wbem.client.CIMClient;
import javax.wbem.cim.CIMClass;
import javax.wbem.cim.CIMException;
import javax.wbem.cim.CIMInstance;
import javax.wbem.cim.CIMNameSpace;
import javax.wbem.cim.CIMObjectPath;
import javax.wbem.client.UserPrincipal;
import javax.wbem.client.PasswordCredential;
* This example enumerates classes and instances. It does deep and
* shallow enumerations on a class that is passed from the command line
public class ClientEnum {
public static void main(String args[]) throws CIMException {
CIMClient cc = null;
CIMObjectPath cop = null;
if (args.length < 4) {
System.out.println("Usage: ClientEnum host user passwd " +
"classname");
System.exit(1);
try {
CIMNameSpace cns = new CIMNameSpace(args[0]);
UserPrincipal up = new UserPrincipal(args[1]);
PasswordCredential pc = new PasswordCredential(args[2]);
cc = new CIMClient(cns, up, pc);
// Get the class name from the command line
cop = new CIMObjectPath(args[3]);
// Do a deep enumeration of the class
Enumeration e = cc.enumerateClasses(cop, true, true, true,
true);
// Will print out all the subclasses of the class.
while (e.hasMoreElements()) {
System.out.println(e.nextElement());
System.out.println("+++++");
// Do a shallow enumeration of the class
e = cc.enumerateClasses(cop, false, true, true, true);
// Will print out the first-level subclasses.
// Do a deep enumeration of the instances of the class
e = cc.enumerateInstances(cop, false, true, true, true, null);
// Will print out all the instances of the class and its
// subclasses.
// Do a shallow enumeration of the instances of the class
e = cc.enumerateInstances(cop, false, false, true, true, null);
// Will print out all the instances of the class.
e = cc.enumerateInstanceNames(cop);
CIMObjectPath opInstance = (CIMObjectPath)e.nextElement();
CIMInstance ci = cc.getInstance(opInstance, false,
true, true, null);
System.out.println(ci);
catch (Exception e) {
System.out.println("Exception: "+e);
// close session.
if (cc != null) {
cc.close();
The following example program returns a list of class names and subclass names.
/* This enumeration contains the names of the classes and subclasses
in the enumerated class. */
Enumeration e = cc.enumerateClassNames(cop, true);
This example program uses the enumNameSpace method in the CIMClient class to print the name of the namespace and all the namespaces contained within the namespace.
import java.rmi.*;
public class EnumNameSpace {
// if not four arguments, show usage and exit
System.out.println("Usage: EnumNameSpace host username " +
"password namespace");
System.exit(1);
try {
// args[0] contains the hostname. We create a CIMNameSpace
// (cns) pointing to the specified namespace on the
// specified host
CIMNameSpace cns = new CIMNameSpace(args[0], "");
// args[1] and args[2] contain the username and password.
// We create a UserPrincipal (up) using the username and
// a PasswordCredential using the password.
// Connect to the CIM Object Manager and pass it the
// CIMNameSpace, UserPrincipal and PasswordCredential objects
// we created.
// Use the namespace (args[3]) to create a CIMObjectPath
CIMObjectPath cop = new CIMObjectPath("", args[3]);
// Enumerate the namespace
Enumeration e = cc.enumNameSpace(cop);
System.out.println((CIMObjectPath)e.nextElement());
} // end while
} catch (Exception e) {
// is we have an exception, catch it and print it out.
System.out.println("Exception: "+ e);
} // end catch
// close session.
if (cc != null) {
cc.close();
