The sample client programs are located in subdirectories of /usr/demo/wbem/client, and are described in the following table.
Table 3–1 Sample Client Programs|
Directory |
Program |
Purpose |
./batching |
./TestBatch host username password classname [[rmi|http]] |
Perform enumerateInstanceName, getClass, and enumerateInstances in a single batching call |
./enumeration |
./ClientEnum host username password classname [[rmi|http]] |
Enumerate classes and instances in the specified class in the default namespace, root\cimv2, on the specified host |
./events |
./Subscribe host username password classname |
Subscribe to lifecycle events for a specified class, print events that occur within one minute of the subscription, and then unsubscribe to the events |
./logging |
./CreateLog host root-username root-password [[rmi|http]] |
Create a log record on the specified host |
./ReadLog host root-username root-password [[rmi|http]] |
Read a log record on the specified host |
./misc |
./DeleteClass host classname root-username root-password [[rmi|http]] |
Delete the specified class in the default namespace root\cimv2 on the specified host |
./DeleteInstances host classname root-username root-password [[rmi|http]] |
Delete instances of the specified class in the default namespace root\cimv2 on the specified host |
./namespace
./CreateNameSpace host parentNS childNS root-username root-password [[rmi|http]] |
Connect to the CIM Object Manager as the specified user, and create a namespace on the specified host |
./DeleteNameSpace host parentNS childNS root-username root-password [[rmi|http]] |
Delete the specified namespace on the specified host |
./query |
./ExampleQuery host username password [[rmi|http]] WQL-query |
Create a test class with sample instances, and perform queries on that class |
./TestQuery host username password [[rmi|http]]WQL-query |
Perform the specified WQL query |
./systeminfo |
./SystemInfo host username password [[rmi|http]] |
Display Solaris processor and system information for the specified host in a separate window |
You must first set the CLASSPATH to include the necessary .jar files before you run the client programs.
Set the CLASSPATH environment variable using one of the following methods:
To use the C shell, type:
% setenv CLASSPATH .:/usr/sadm/lib/wbem.jar:/usr/sadm/lib/xml.jar :/usr/sadm/lib/wbem/sunwbem.jar:/usr/sadm/lib/wbem/extension |
To use the Bourne shell, type:
Most of the sample client programs accept an optional parameter that specifies the protocol to use to connect to the CIM Object Manager. RMI is the default protocol.
For instance, the following example runs the SystemInfo program by connecting to myhost as the root user with the secret password using the HTTP protocol.
% java SystemInfo myhost root secret http |
