This chapter provides an overview of the Managed Object Format (MOF) compiler. This chapter also describes how to create JavaBeansTM components by using the -j option to the mofcomp command. This chapter covers the following topics.
For more information on the MOF Compiler, see the mofcomp(1M) man page.
Managed Object Format (MOF) is a compiled language developed by the Distributed Management Task Force (DMTF). The MOF language defines static and dynamic classes and instances for CIM and WBEM. You can use the CIM and Solaris MOF files that are included with Solaris WBEM Services. You can also create your own MOF files. For more information on creating your own MOF files using the DMTF's MOF language, see the DMTF Web site at http://www.dmtf.org.
The MOF Compiler, mofcomp(1M) performs the following tasks:
Parses MOF files
Converts the classes and instances to Java programming language classes
Adds the classes to the CIM Object Manager Repository in the default (root\cimv2) or other specified namespace
During a Solaris installation, the MOF compiler compiles the bundled MOF files that describe the CIM and Solaris Schema and adds those files to the CIM Object Manager Repository.
In the context of WBEM, JavaBeans components, or beans, define methods for accessing and manipulating CIM classes and data. To simplify your development efforts, you can use the -j option to the mofcomp command to generate beans from the CIM classes in your MOF files. These automatically-generated beans define the interfaces. You must add the implementation code.
To safeguard your program from changes that you make to the underlying JavaBeans implementation, use the interfaces rather than the original JavaBeans components.
When you specify the -j option with mofcomp, a Java interface, CIMBean.java, and a bean that implements that interface, CIMBeanImpl.java, are generated. CIMBeanImpl.javacontains all of the code that is common to the generated beans. All generated Java interfaces extend from CIMBean.java. All generated beans extend fromCIMBeanImpl.java, and inherit the base implementation.
For each CIM class that is defined in a MOF file, the MOF compiler JavaBeans generation feature generates a Java programming language interface that contains the following methods:
Accessor and mutator methods for the properties that are defined in the MOF file
Methods that are comparable to the invokeMethods that are defined in the MOF file
For each invokeMethod that contains an OUT qualified parameter in a CIM class, a container interface that holds the output that the invoking of the method generates is generated. These interfaces are named CIMClass_MethodNameOutput.java. An instance of this CIMClass_MethodNameOutput.java container interface is required as the last parameter of the bean's method. This container interface is required because the object datatype or datatypes that the bean's method takes as parameters are not mutable. Therefore these data types cannot be used to hold both input and output data.
You must include the PACKAGE element in your MOF file to take advantage of the -j option. In addition, you can specify the IMPORTS and EXCEPTIONS elements in the following format:
PACKAGE=NameOfJavaPackage IMPORTS=JavaClassName1:JavaClassName2:... EXCEPTIONS=Exception1:Exception2:...
The following table describes these elements.
Table 7–1 MOF File Elements|
Element |
Description |
PACKAGE |
Required. Specifies the name of the Java package that contains the source files generated by the MOF compiler. |
IMPORTS |
Optional. Specifies the names of the Java classes to import into the generated source files. These classes are separated with a colon (:). You can specify as many Java classes as you want, on as many lines as you want. |
EXCEPTIONS |
Optional. Specifies the names of the Java exceptions that are included in the generated source files. These exceptions are separated with a colon (:). You can specify as many Java class exceptions as you want, on as many lines as you want. Note – If you specify EXCEPTIONS, you must specify IMPORTS. |
The following table describes how CIM elements map to elements of the Java programming language.
Table 7–2 How CIM Elements Map to Java Elements|
CIM Element |
Java Element |
Class |
The CIM class name is used as the basis for the name of the generated Java source files. The generated Java classes follow the same inheritance as defined in the class-subclass relationships in the MOF. |
Property |
An accessor and a mutator method are created for each CIM property. The CIM property name is used as the basis for the associated accessor and mutator methods. |
Method |
For each CIM method, a comparable Java method is created. The method name is used as the basis for the related Java method name. The return value is the same, accounting for the Java data type mapping. Input and output parameters are used as arguments to the Java method. Output parameters are not directly included in the method signature. Instead, output parameters are encapsulated in an output container object that is included as a method parameter. |
Qualifier | |
Association |
Nothing specific required. |
Indication |
Reference |
For each CIM reference, a reference to a generated Java interface is created. |
Trigger |
Schema |
The following table describes how CIM data types map to Java data types.
Table 7–3 How CIM Data Types Map to Java Data Elements|
CIM Data Type |
Java Data Type |
Accessor Method |
Mutator Method |
uint8 X |
UnsignedInt8 |
UnsignedInt8 getX(); |
void setX(UnsignedInt8 x); |
sint8 X |
Byte |
Byte getX(); |
void setX(Byte x); |
uint16 X |
UnsignedInt16 |
UnsignedInt16 getX(); |
void setX(UnsignedInt16 x); |
sint16 X |
Short |
Short getX(); |
void setX(Short x); |
uint32 X |
UnsignedInt32 |
UnsignedInt32 getX(); |
void setX(UnsignedInt32 x); |
sint32 X |
Integer |
Integer getX(); |
void setX(Integer x); |
uint64 X |
UnsignedInt64 |
UnsignedInt64 getX(); |
void setX(UnsignedInt64 x); |
sint64 X |
Long |
Long getX(); |
void setX(Long x); |
String X |
String |
String getX(); |
void setX(String x); |
Boolean X |
Boolean |
Boolean isX(); |
void setX(Boolean x); |
real32 X |
Float |
Float getX(); |
void setX(Float x); |
real64 X |
Double |
Double getX(); |
void setX(Double x); |
DateTime X |
CIMDateTime |
CIMDateTime getX(); |
void setX(CIMDateTime x); |
Reference X |
CIMObjectPath |
CIMObjectPath getX(); |
void setX(CIMObjectPath x); |
char16 X |
Character |
Character getX(); |
void setX(Character x); |
The following table lists the meta qualifiers that refine the definition of the meta constructs in the model. These qualifiers are mutually exclusive and are used to refine the actual usage of an object class or property declaration within the MOF syntax.
Table 7–4 Meta Qualifiers|
Qualifier |
Scope |
Type |
Meaning |
Association |
class |
Boolean |
No affect on mapping |
Indication |
class |
Boolean |
Class is abstract |
The following table lists the standard qualifiers and the effect that these qualifiers have on the mapping of a CIM object to a bean. There is no support for optional qualifiers. Javadoc API documentation is produced for each interface and class based on this mapping.
Table 7–5 Standard Qualifiers|
Qualifier |
Scope |
Meaning |
ABSTRACT |
Class, Association, Indication |
The class is abstract and has no effect on the Java programming language interfaces. |
DESCRIPTION |
Any |
The information that is provided generates Javadoc comments in the source file. |
DISPLAYNAME |
Property |
An accessor method for the display name is created: public String displayNameForProperty(); |
IN |
Parameter |
Determines the method signature. |
OUT |
Parameter |
Determines the method parameter signature and return values. |
TERMINAL |
Class |
Class or interface is final. |
UNITS |
Property, Method, Parameter |
Another accessor method is created: public String getpropertyUnits(); |
VALUEMAP |
Beans contain generated constants for each property in a CIM class that has a CIM ValueMap or a Values qualifier. The way in which the constant name and constant value are obtained to generate these class variables depends on the data type of the property and the qualifiers that the property possesses. Note – The ValueMap and Values qualifiers as defined in the CIM specification have meanings contrary to what the qualifier names might imply. ValueMap defines the legal set of values for a property. Values provides translation between an integer value and a string. |
VALUES |
Beans contain generated constants for each property in a CIM class that has a CIM ValueMap or a Values qualifier. The way in which the constant name and constant value are obtained to generate these class variables depends on the data type of the property and qualifiers that the property possesses. Note – The ValueMap and Values qualifiers as defined in the CIM specification have meanings contrary to what the qualifier names might imply. ValueMap defines the legal set of values for a property. Values provides translation between an integer value and a string. |
VERSION |
Class, Schema, Association, Indication |
Class possesses a getClassVersion() method |
The following table describes how MOF elements map to Java elements.
Table 7–6 How MOF Elements Map to Java Elements|
MOF Element |
Java Element |
Description qualifier |
Description of the class, property, or method |
Complete MOF representation of the class |
The Javadoc class description for both the Java interface and the implementation bean |
The following example shows the JavaBeans components that are produced when you use the mofcomp command with the -j option.
You must run the mofcomp command as root or as a user with write access to the namespace in which you are compiling.
Avoid specifying both the -u (user) and -p (password) options when running the mofcomp command. You want to avoid having to type your password directly on the command line. Instead, specify only the -u option so that you are prompted to specify an encrypted password.
/usr/sadm/bin/mofcomp -u root -p mypassword -o /tmp -j /tmp/bean.txt /usr/sadm/mof/Simple.mof |
The content of /usr/sadm/mof/Simple.mof is as follows:
#pragma include ("CIM_Core26.mof")
class Simple_Class {
[Key, Description ("Name of the class.") ]
string Name;
[Description ("Method to print the contents of the class.") ]
string printClass();
The content of /tmp/bean.txt is as follows:
/tmp/bean.txt ---------- PACKAGE=foo.com IMPORTS=java.lang.Exception EXCEPTIONS=Exception |
The content of CIMBean.java is as follows:
package foo.com;
import javax.wbem.cim.CIMException;
import javax.wbem.client.CIMOMHandle;
import javax.wbem.cim.CIMInstance;
* This Interface defines the methods that must be implemented by
* CIMBeanImpl and its subclasses. CIMBeanImpl constitutes the base
* class of the Java source generated by 'mofcomp -j'.
public interface CIMBean {
* This method returns the CIMBean's CIMOMHandle.
* @return CIMOMHandle handle to the CIMOM
public CIMOMHandle getCIMOMHandle();
* This method sets the CIMBean's CIMOMHandle to the specifed value.
* @param CIMOMHandle handle to the CIMOM
public void setCIMOMHandle(CIMOMHandle handle);
* This method returns the CIMBean's CIMInstance.
* @return CIMInstance handle to the CIMInstance being managed
public CIMInstance getCIMInstance();
* This method sets the CIMBean's CIMInstance to the specified value.
* @param CIMInstance handle to the CIMInstance being managed
public void setCIMInstance(CIMInstance instance);
* This method makes the remote call to update the CIMInstance in the
* CIMOM.
public void update() throws CIMException;
* This method makes the remote call to update the specified
* CIMProperty of the CIMInstance in the CIMOM.
* @param String property name to update in the CIMInstance
* @param Object property value to update in the CIMProperty
public void update(String propName, Object value) throws CIMException;
* This method makes the remote call to delete the CIMInstance in the
* CIMOM.
public void delete() throws CIMException;
* This method returns a string array of the Key qualified property
* name(s) in the CIMInstance. This is needed to build the
* CIMObjectPath for the CIMInstance if it does not contain any
* qualifier information.
* @return String Version qualifier value or "-1" if there isn't
* one
public String[] getBeanKeys();
* This method returns the CIM class's Version qualifier value or
* '-1' if it does not have this qualifier.
* @return String[] array of the key qualified property names
public String getBeanVersion();
* This method returns a string representation of the CIMBean.
* This method is intended for debug purposes and the format of the
* string may vary from implementation to implementation. The string
* returned may be empty, but may not be null.
* @return String string representation of the Bean
public String toString();
} // Interface CIMBean
The content of CIMBeanImpl.java is as follows:
package foo.com;
import java.io.Serializable;
import java.util.*;
import javax.wbem.cim.CIMObjectPath;
import javax.wbem.cim.CIMValue;
* This Class implements the CIMBean Interface. It is the base Class
* of the Java source code generated by 'mofcomp -j'.
public class CIMBeanImpl implements CIMBean, Serializable {
private CIMInstance cimInstance = null;
private CIMOMHandle cimomHandle = null;
* This default constructor takes no parameters and creates an empty
* instance of CIMBeanImpl.
public CIMBeanImpl() {
super();
} // constructor
* This constructor takes the specified CIMOMHandle and CIMInstance and
* creates a CIMBeanImpl.
public CIMBeanImpl(CIMOMHandle handle, CIMInstance instance) {
super();
cimomHandle = handle;
cimInstance = instance;
} // constructor
public CIMOMHandle getCIMOMHandle() {
return (cimomHandle);
} // getCIMOMHandle
public void setCIMOMHandle(CIMOMHandle handle) {
this.cimomHandle = handle;
} // setCIMOMHandle
public CIMInstance getCIMInstance() {
return (cimInstance);
} // getCIMInstance
* value.
public void setCIMInstance(CIMInstance instance) {
this.cimInstance = instance;
} // setCIMInstance
* the CIMOM.
public void update() throws CIMException {
cimomHandle.setInstance(getObjectPath(), cimInstance);
} // update
public void update(String propName, Object value) throws CIMException {
cimomHandle.setProperty(getObjectPath(), propName, new CIMValue(value));
} // update
* CIMOM.
public void delete() throws CIMException {
cimomHandle.deleteInstance(getObjectPath());
} // delete
* This is a convenience method for use by subclasses to get the
* Object contained in the given CIMProperty's CIMValue.
* NOTE: The Object returned may be null.
* @param String property name whose value should be retrieved
* @return Object object contained in the CIMProperty's CIMValue
protected Object getProperty(String propName) {
try {
return (cimInstance.getProperty(propName).getValue().getValue());
} catch (NullPointerException npe) {
return ((Object)null);
} // getProperty
* the String[] equivalent to the Vector contained in the given
* CIMProperty's CIMValue.
* NOTE: The String[] returned may be null.
* @param String property name to get the value for
* @param String[] property Values qualifier data
* @param Object[] property ValueMap qualifier data
* @return String[] container of constants for property value
protected String[] getArrayProperty(String propName, String[]
valueArr, Object[] valueMapArr) {
List propList = null;
try {
propList =
((List)cimInstance.getProperty(propName).getValue().getValue());
if (propList != null) {
String[] returnArr;
returnArr = new String[propList.size()];
ListIterator listIterator = propList.listIterator();
int counter = 0;
while (listIterator.hasNext()) {
returnArr[counter] = valueArr[getArrayIndex(valueMapArr,
listIterator.next())];
counter++;
return (returnArr);
return ((String[])null);
} // getArrayProperty
* This method gets the CIMInstance referenced by the property
* value (i.e., the object path specified) and sets it in the
* specified Bean. This method is used by accessor methods of
* Association properties.
* @param CIMObjectPath object path for the CIMInstance
* @param CIMBeanImpl Bean container for CIMInstance retrieved
protected void getAssociationProperty(CIMObjectPath cop,
CIMBeanImp bean) throws CIMException {
cop.setNameSpace("");
CIMInstance ci = cimomHandle.getInstance(cop, false, true, true,
(String[])null);
bean.setCIMInstance(ci);
bean.setCIMOMHandle(cimomHandle);
} // getAssociationProperty
* This is a convenience method for use by subclasses to set a
* CIMValue containing the specified Object value in the
* CIMProperty of the specified name.
* @param String property name to set a new value for
* @param Object property value to update in the CIMInstance
protected void setProperty(String propName, Object propValue)throws
IllegalArgumentException {
cimInstance.setProperty(propName, new CIMValue(propValue));
} // setProperty
* CIMValue containing a Vector equivalent to the specified
* String[] in the CIMProperty of the specified name.
* @param String[] property value to set in the CIMInstance
protected void setArrayProperty(String propName, String[] valueArr,
Object[] valueMapArr, String[] propValues) {
Vector vPropValue = new Vector(propValues.length);
for (int i = 0; i < propValues.length; i++) {
vPropValue.addElement(valueMapArr[getArrayIndex(valueArr,
propValues[i])]);
setProperty(propName, vPropValue);
} // setArrayProperty
public String[] getBeanKeys() {
} // getBeanKeys
* This method returns the CIMObjectPath of the class's CIMInstance.
* @return CIMObjectPath object path for the CIMInstance
protected CIMObjectPath getObjectPath() {
CIMObjectPath cop = new CIMObjectPath(cimInstance.getClassName());
Vector vKeys = cimInstance.getKeyValuePairs();
if ((vKeys != null) && (vKeys.size() > 0)) {
cop.setKeys(vKeys);
} else {
String[] keyArr = getBeanKeys();
if (keyArr != null) {
String keyProperty;
for (int i = 0; i < keyArr.length; i++) {
keyProperty = keyArr[i];
cop.addKey(keyProperty,
(cimInstance.getProperty(keyProperty)).getValue());
return (cop);
} // getObjectPath
* This convenience method returns the index of the specified
* object in the specified array, or '-1' if the object is not
* contained in the array.
* @param Object[] Object array to find index of Object in
* @param Object Object to find index of in Object array
* @return int index of Object in Object array
protected int getArrayIndex(Object[] objArr, Object obj) {
List arrList = Arrays.asList(objArr);
return (arrList.indexOf(obj));
} // getArrayIndex
* This method returns the CIM class's Version qualifier value, or
* @return String Version qualifier value or '-1' if there isn't
* one
public String getBeanVersion() {
return ("-1");
} // getBeanVersion
* the string may vary from implementation to implementation.
* The string returned may be empty, but may not be null.
public String toString() {
return (cimInstance.toString());
} // toString
} // Class CIMBeanImpl
The content of Simple_ClassBean.java is as follows:
package foo.com;
import javax.wbem.client.*;
import javax.wbem.cim.*;
import java.util.*;
import java.lang.Exception;
* This Interface contains accessor and mutator methods for all
* properties defined in CIM class Simple_Class as well as methods
* comparable to the invokeMethods defined for this class. This Interface
* is implemented by Simple_ClassBeanImpl. The CIM class Simple_Class is
* described as follows:
public interface Simple_ClassBean extends CIMBean {
* This method returns the Simple_Class.Name property value. This
* property is described as follows:
* Name of the class.
* @return String current Name property value
* @exception Exception
public String getName() throws Exception;
* This method sets the Simple_Class.Name property value. This
* @param String new Name property value
public void setName(String name) throws Exception;
* This method invokes the Simple_Class.printClass() method. This
* method is described as follows:
* Method to print the contents of the class.
* @return String return value of printClass() invokation
public String printClass() throws Exception, CIMException;
} // Interface Simple_ClassBean
The content of Simple_ClassBeanImpl.java is as follows:
package foo.com;
import java.util.*;
* This class contains accessor and mutator methods for all properties
* defined in the CIM class Simple_Class as well as methods comparable
* to the invokeMethods defined for this class. This class implements
* the Simple_ClassBean interface. The CIM class Simple_Class is
public class Simple_ClassBeanImpl extends CIMBeanImpl implements
Simple_ClassBean {
private final static String[] keysArr = {"Name"};
* This constructor creates a Simple_ClassBeanImpl class which
* implements the Simple_ClassBean interface, and encapsulates the
* CIM class Simple_Class in a bean. The CIM class Simple_Class
* is described as follows:
public Simple_ClassBeanImpl(CIMOMHandle handle, CIMInstance instance)
super(handle, instance);
} // constructor
* This method returns an array of Strings with the names of the key
* qualified properties defined for the CIM class. This method is
* used to build the CIMObjectPath of the CIMInstance managed by
* the Bean in the case that the key qualifiers are not included
* in the CIMInstance.
return keysArr;
} // getBeanKeys
public String getName() throws Exception {
return (String)getProperty("Name");
} // getName
public void setName(String name) throws Exception {
setProperty("Name", name);
} // setName
public String printClass() throws Exception, CIMException {
Vector vInParams = new Vector();
Vector vOutParams = new Vector();
CIMValue cv = cimomHandle.invokeMethod(cimInstance.getObjectPath(),
"printClass", vInParams, vOutParams);
return (String)cv.getValue();
} // printClass
} // Class Simple_ClassBeanImpl
