The following table describes how CIM elements map to elements of the Java programming language.
Table 7–2 How CIM Elements Map to Java Elements|
CIM Element |
Java Element |
Class |
The CIM class name is used as the basis for the name of the generated Java source files. The generated Java classes follow the same inheritance as defined in the class-subclass relationships in the MOF. |
Property |
An accessor and a mutator method are created for each CIM property. The CIM property name is used as the basis for the associated accessor and mutator methods. |
Method |
For each CIM method, a comparable Java method is created. The method name is used as the basis for the related Java method name. The return value is the same, accounting for the Java data type mapping. Input and output parameters are used as arguments to the Java method. Output parameters are not directly included in the method signature. Instead, output parameters are encapsulated in an output container object that is included as a method parameter. |
Qualifier | |
Association |
Nothing specific required. |
Indication |
Reference |
For each CIM reference, a reference to a generated Java interface is created. |
Trigger |
Schema |
The following table describes how CIM data types map to Java data types.
Table 7–3 How CIM Data Types Map to Java Data Elements|
CIM Data Type |
Java Data Type |
Accessor Method |
Mutator Method |
uint8 X |
UnsignedInt8 |
UnsignedInt8 getX(); |
void setX(UnsignedInt8 x); |
sint8 X |
Byte |
Byte getX(); |
void setX(Byte x); |
uint16 X |
UnsignedInt16 |
UnsignedInt16 getX(); |
void setX(UnsignedInt16 x); |
sint16 X |
Short |
Short getX(); |
void setX(Short x); |
uint32 X |
UnsignedInt32 |
UnsignedInt32 getX(); |
void setX(UnsignedInt32 x); |
sint32 X |
Integer |
Integer getX(); |
void setX(Integer x); |
uint64 X |
UnsignedInt64 |
UnsignedInt64 getX(); |
void setX(UnsignedInt64 x); |
sint64 X |
Long |
Long getX(); |
void setX(Long x); |
String X |
String |
String getX(); |
void setX(String x); |
Boolean X |
Boolean |
Boolean isX(); |
void setX(Boolean x); |
real32 X |
Float |
Float getX(); |
void setX(Float x); |
real64 X |
Double |
Double getX(); |
void setX(Double x); |
DateTime X |
CIMDateTime |
CIMDateTime getX(); |
void setX(CIMDateTime x); |
Reference X |
CIMObjectPath |
CIMObjectPath getX(); |
void setX(CIMObjectPath x); |
char16 X |
Character |
Character getX(); |
void setX(Character x); |
The following table lists the meta qualifiers that refine the definition of the meta constructs in the model. These qualifiers are mutually exclusive and are used to refine the actual usage of an object class or property declaration within the MOF syntax.
Table 7–4 Meta Qualifiers|
Qualifier |
Scope |
Type |
Meaning |
Association |
class |
Boolean |
No affect on mapping |
Indication |
class |
Boolean |
Class is abstract |
The following table lists the standard qualifiers and the effect that these qualifiers have on the mapping of a CIM object to a bean. There is no support for optional qualifiers. Javadoc API documentation is produced for each interface and class based on this mapping.
Table 7–5 Standard Qualifiers|
Qualifier |
Scope |
Meaning |
ABSTRACT |
Class, Association, Indication |
The class is abstract and has no effect on the Java programming language interfaces. |
DESCRIPTION |
Any |
The information that is provided generates Javadoc comments in the source file. |
DISPLAYNAME |
Property |
An accessor method for the display name is created: public String displayNameForProperty(); |
IN |
Parameter |
Determines the method signature. |
OUT |
Parameter |
Determines the method parameter signature and return values. |
TERMINAL |
Class |
Class or interface is final. |
UNITS |
Property, Method, Parameter |
Another accessor method is created: public String getpropertyUnits(); |
VALUEMAP |
Beans contain generated constants for each property in a CIM class that has a CIM ValueMap or a Values qualifier. The way in which the constant name and constant value are obtained to generate these class variables depends on the data type of the property and the qualifiers that the property possesses. Note – The ValueMap and Values qualifiers as defined in the CIM specification have meanings contrary to what the qualifier names might imply. ValueMap defines the legal set of values for a property. Values provides translation between an integer value and a string. |
VALUES |
Beans contain generated constants for each property in a CIM class that has a CIM ValueMap or a Values qualifier. The way in which the constant name and constant value are obtained to generate these class variables depends on the data type of the property and qualifiers that the property possesses. Note – The ValueMap and Values qualifiers as defined in the CIM specification have meanings contrary to what the qualifier names might imply. ValueMap defines the legal set of values for a property. Values provides translation between an integer value and a string. |
VERSION |
Class, Schema, Association, Indication |
Class possesses a getClassVersion() method |
The following table describes how MOF elements map to Java elements.
Table 7–6 How MOF Elements Map to Java Elements|
MOF Element |
Java Element |
Description qualifier |
Description of the class, property, or method |
Complete MOF representation of the class |
The Javadoc class description for both the Java interface and the implementation bean |
