This section describes how to start and use Sun WBEM User Manager.
Become superuser.
In a command window, type the following command:
# /usr/sadm/bin/wbemadmin |
Sun WBEM User Manager starts, and a Login dialog box opens.
Context-help information is available in the Context Help panel when you click on the fields in the Login dialog box.
Fill in the fields on the Login dialog box.
In the User Name field, type the user name.
You must have read access to the root\security namespace to log in. By default, Solaris users have guest privileges, which grant them read access to the default namespaces. Users with read access can view but not change user privileges.
You must log in as root or a user with write access to the root\security namespace to grant access rights to users.
In the Password field, type the password for the user account.
Click OK.
The User Manager dialog box opens. The dialog box contains a list of users and their access rights to WBEM objects within the namespaces on the current host.
Start Sun WBEM User Manager.
In the Users Access portion of the dialog box, click Add.
A dialog box opens that lists the available namespaces.
Type the name of a Solaris user account in the User Name field.
Select a namespace from the listed namespaces.
Click OK.
The user name is added to the User Manager dialog box.
To save changes and close the User Manager dialog box, click OK. To save changes and keep the dialog box open, click Apply.
The user that you specified is granted read access to CIM objects in the namespace that you selected.
Select the user whose access rights you want to change.
Set the user privileges. To grant the user read-only access, click the Read check box. To grant the user write access, click the Write check box.
In the Users Access portion of the dialog box, select the user name for which you want to remove access rights.
Click Delete to delete the user's access rights to the namespace.
A confirmation dialog box opens. This dialog box prompts you to confirm your decision to delete the user's access rights.
To confirm, click OK.
In the Namespace Access portion of the dialog box, click Add.
A dialog box opens. The dialog box lists the available namespaces.
Select the namespace for which you want to set access rights.
By default, users have read-only access to a namespace.
To allow no access to the namespace, make sure that the Read and Write check boxes are not selected.
To allow write access, select Write.
To allow read access, select Read.
In the Namespace Access portion of the dialog box, select the namespace for which you want to remove access control, and then click Delete.
Access control is removed from the namespace, and the namespace is removed from the list of namespaces on the Sun WBEM User Manager dialog box.
