A dynamic object can establish dependencies explicitly or through filters. Each of these mechanisms can be augmented with a runpath, which directs the runtime linker to search for and load the required dependency. String names used to record filters, dependencies and runpath information can be augmented with the reserved dynamic string tokens:
$ISALIST
$OSNAME, $OSREL and $PLATFORM
$ORIGIN
The following sections provide examples of how each of these tokens may be employed.
The dynamic token $ISALIST is expanded at runtime to reflect the native instruction sets executable on this platform, as displayed by the utility isalist(1). This token is available for filters or runpath definitions.
Any string name that incorporates the $ISALIST token is effectively duplicated into multiple strings. Each string is assigned one of the available instruction sets.
The following example shows how the auxiliary filter libfoo.so.1 can be designed to access an instruction set specific filtee libbar.so.1.
$ LD_OPTIONS='-f /opt/ISV/lib/$ISALIST/libbar.so.1' \ cc -o libfoo.so.1 -G -K pic -h libfoo.so.1 -R. foo.c $ dump -Lv libfoo.so.1 | egrep "SONAME|AUXILIARY" [1] SONAME libfoo.so.1 [2] AUXILIARY /opt/ISV/lib/$ISALIST/libbar.so.1 |
Or alternatively the runpath can be used.
$ LD_OPTIONS='-f libbar.so.1' \ cc -o libfoo.so.1 -G -K pic -h libfoo.so.1 -R'/opt/ISV/lib/$ISALIST' foo.c $ dump -Lv libfoo.so.1 | egrep "RUNPATH|AUXILIARY" [1] RUNPATH /opt/ISV/lib/$ISALIST [2] AUXILIARY libbar.so.1 |
In either case the runtime linker uses the platform available instruction list to construct multiple search paths. For example, the following application is dependent on libfoo.so.1 and executed on a SUNW,Ultra-2:
$ ldd -ls prog ..... find object=libbar.so.1; required by ./libfoo.so.1 search path=/opt/ISV/lib/$ISALIST (RPATH from file ./libfoo.so.1) trying path=/opt/ISV/lib/sparcv9+vis/libbar.so.1 trying path=/opt/ISV/lib/sparcv9/libbar.so.1 trying path=/opt/ISV/lib/sparcv8plus+vis/libbar.so.1 trying path=/opt/ISV/lib/sparcv8plus/libbar.so.1 trying path=/opt/ISV/lib/sparcv8/libbar.so.1 trying path=/opt/ISV/lib/sparcv8-fsmuld/libbar.so.1 trying path=/opt/ISV/lib/sparcv7/libbar.so.1 trying path=/opt/ISV/lib/sparc/libbar.so.1 |
Or an application with similar dependencies is executed on an MMX configured Pentium Pro:
$ ldd -ls prog ..... find object=libbar.so.1; required by ./libfoo.so.1 search path=/opt/ISV/lib/$ISALIST (RPATH from file ./libfoo.so.1) trying path=/opt/ISV/lib/pentium_pro+mmx/libbar.so.1 trying path=/opt/ISV/lib/pentium_pro/libbar.so.1 trying path=/opt/ISV/lib/pentium+mmx/libbar.so.1 trying path=/opt/ISV/lib/pentium/libbar.so.1 trying path=/opt/ISV/lib/i486/libbar.so.1 trying path=/opt/ISV/lib/i386/libbar.so.1 trying path=/opt/ISV/lib/i86/libbar.so.1 |
The use of $ISALIST within a filter enables one or more filtees to provide implementations of interfaces defined within the filter.
Any interface defined in a filter can result in an exhaustive search of all potential filtees in an attempt to locate the required interface. If filtees are being employed to provide performance critical functions, this exhaustive filtee searching can be counterproductive.
A filtee can be built with the link-editor's -z endfiltee option to indicate that it is the last of the available filtees. This option terminates any further filtee searching for that filter. From the previous SPARC example, if the sparcv9 filtee existed, and was tagged with -z endfiltee, the filtee searches would be:
$ ldd -ls prog ..... find object=libbar.so.1; required by ./libfoo.so.1 search path=/opt/ISV/lib/$ISALIST (RPATH from file ./libfoo.so.1) trying path=/opt/ISV/lib/sparcv9+vis/libbar.so.1 trying path=/opt/ISV/lib/sparcv9/libbar.so.1 |
The dynamic tokens $OSNAME, $OSREL and $PLATFORM are expanded at runtime to provide system specific information. These tokens are available for filters, runpath, or dependency definitions.
$OSNAME expands to reflect the name of the operating system, as displayed by the utility uname(1) with the -s option. $OSREL expands to reflect the operating system release level, as displayed by uname -r. $PLATFORM expands to reflect the underlying hardware implementation, as displayed by uname -i.
The following example shows how the auxiliary filter libfoo.so.1 can be designed to access a platform specific filtee libbar.so.1.
$ LD_OPTIONS='-f /usr/platform/$PLATFORM/lib/libbar.so.1' \ cc -o libfoo.so.1 -G -K pic -h libfoo.so.1 -R. foo.c $ dump -Lv libfoo.so.1 | egrep "SONAME|AUXILIARY" [1] SONAME libfoo.so.1 [2] AUXILIARY /usr/platform/$PLATFORM/lib/libbar.so.1 |
This mechanism is used in the Solaris operating environment to provide platform specific extensions to the shared object /usr/lib/libc.so.1.
Typically, an unbundled product is designed to be installed in a standalone, unique location. This product is composed of binaries, shared object dependencies, and associated configuration files. For example, the unbundled product ABC might have the layout shown in the following figure.
Assume that the product is designed for installation under /opt. Normally, you would augment the PATH with /opt/ABC/bin to locate the product's binaries. Each binary locates their dependencies using a hard-coded runpath within the binary. For the application abc, this runpath would be:
% cc -o abc abc.c -R/opt/ABC/lib -L/opt/ABC/lib -lA % dump -Lv abc [1] NEEDED libA.so.1 [2] RUNPATH /opt/ABC/lib |
and similarly for the dependency libA.so.1 this would be:
% cc -o libA.so.1 -G -Kpic A.c -R/opt/ABC/lib -L/opt/ABC/lib -lB % dump -Lv libA.so.1 [1] NEEDED libB.so.1 [2] RUNPATH /opt/ABC/lib |
This dependency representation works until the product is installed in some directory other than the recommended default.
The dynamic token $ORIGIN expands to the directory in which an object originated. This token is available for filters, runpath, or dependency definitions. Use this technology to redefine the unbundled application to locate its dependencies in terms of $ORIGIN:
% cc -o abc abc.c '-R$ORIGIN/../lib' -L/opt/ABC/lib -lA % dump -Lv abc [1] NEEDED libA.so.1 [2] RUNPATH $ORIGIN/../lib |
and the dependency libA.so.1 can also be defined in terms of $ORIGIN:
% cc -o libA.so.1 -G -Kpic A.c '-R$ORIGIN' -L/opt/ABC/lib -lB % dump -Lv libA.so.1 [1] NEEDED libB.so.1 [2] RUNPATH $ORIGIN |
If this product is now installed under /usr/local/ABC and the user's PATH is augmented with /usr/local/ABC/bin, invocation of the application abc result in a pathname lookup for its dependencies as follows:
% ldd -s abc ..... find object=libA.so.1; required by abc search path=$ORIGIN/../lib (RPATH from file abc) trying path=/usr/local/ABC/lib/libA.so.1 libA.so.1 => /usr/local/ABC/lib/libA.so.1 find object=libB.so.1; required by /usr/local/ABC/lib/libA.so.1 search path=$ORIGIN (RPATH from file /usr/local/ABC/lib/libA.so.1) trying path=/usr/local/ABC/lib/libB.so.1 libB.so.1 => /usr/local/ABC/lib/libB.so.1 |
Another issue related to dependency location is how to establish a model whereby unbundled products express dependencies between themselves.
For example, the unbundled product XYZ might have dependencies on the product ABC. This dependency can be established by a host package installation script. This script generates a symbolic link to the installation point of the ABC product, as shown in the following figure.
The binaries and shared objects of the XYZ product can represent their dependencies on the ABC product using the symbolic link. This link is now a stable reference point. For the application xyz, this runpath would be:
% cc -o xyz xyz.c '-R$ORIGIN/../lib:$ORIGIN/../ABC/lib' \ -L/opt/ABC/lib -lX -lA % dump -Lv xyz [1] NEEDED libX.so.1 [2] NEEDED libA.so.1 [3] RUNPATH $ORIGIN/../lib:$ORIGIN/../ABC/lib |
and similarly for the dependency libX.so.1 this runpath would be:
% cc -o libX.so.1 -G -Kpic X.c '-R$ORIGIN:$ORIGIN/../ABC/lib' \ -L/opt/ABC/lib -lY -lC % dump -Lv libX.so.1 [1] NEEDED libY.so.1 [2] NEEDED libC.so.1 [3] RUNPATH $ORIGIN:$ORIGIN/../ABC/lib |
If this product is now installed under /usr/local/XYZ, its post-install script would be required to establish a symbolic link of:
% ln -s ../ABC /usr/local/XYZ/ABC |
If the user's PATH is augmented with /usr/local/XYZ/bin, then invocation of the application xyz result in a pathname lookup for its dependencies as follows:
% ldd -s xyz ..... find object=libX.so.1; required by xyz search path=$ORIGIN/../lib:$ORIGIN/../ABC/lib (RPATH from file xyz) trying path=/usr/local/XYZ/lib/libX.so.1 libX.so.1 => /usr/local/XYZ/lib/libX.so.1 find object=libA.so.1; required by xyz search path=$ORIGIN/../lib:$ORIGIN/../ABC/lib (RPATH from file xyz) trying path=/usr/local/XYZ/lib/libA.so.1 trying path=/usr/local/ABC/lib/libA.so.1 libA.so.1 => /usr/local/ABC/lib/libA.so.1 find object=libY.so.1; required by /usr/local/XYZ/lib/libX.so.1 search path=$ORIGIN:$ORIGIN/../ABC/lib \ (RPATH from file /usr/local/XYZ/lib/libX.so.1) trying path=/usr/local/XYZ/lib/libY.so.1 libY.so.1 => /usr/local/XYZ/lib/libY.so.1 find object=libC.so.1; required by /usr/local/XYZ/lib/libX.so.1 search path=$ORIGIN:$ORIGIN/../ABC/lib \ (RPATH from file /usr/local/XYZ/lib/libX.so.1) trying path=/usr/local/XYZ/lib/libC.so.1 trying path=/usr/local/ABC/lib/libC.so.1 libC.so.1 => /usr/local/ABC/lib/libC.so.1 find object=libB.so.1; required by /usr/local/ABC/lib/libA.so.1 search path=$ORIGIN (RPATH from file /usr/local/ABC/lib/libA.so.1) trying path=/usr/local/ABC/lib/libB.so.1 libB.so.1 => /usr/local/ABC/lib/libB.so.1 |
In a secure process, the expansion of the $ORIGIN string is allowed only if it expands to a trusted directory. The occurrence of other relative path names, poses a security risk.
A path like $ORIGIN/../lib apparently points to a fixed location, fixed by the location of the executable. However, the location is not actually fixed. A writable directory in the same file system could exploit a secure program that uses $ORIGIN.
The following example shows this possible security breach if $ORIGIN was arbitrarily expanded within a secure process.
% cd /worldwritable/dir/in/same/fs % mkdir bin lib % ln $ORIGIN/bin/program bin/program % cp ~/crooked-libc.so.1 lib/libc.so.1 % bin/program ..... using crooked-libc.so.1 |
You can use the utility crle(1) to specify trusted directories that enable secure applications to use $ORIGIN. Administrators who use this technique should ensure that the target directories are suitably protected from malicious intrusion.
