This code sequence can only be used from within a dynamic executable to reference a TLS variable defined within the executable. If this is the case, the static tlsoffset is known at link-edit time and no runtime relocations are required.
Table 8–6 SPARC: 32-bit and 64-bit Local Executable Thread-Local Variable Access Codes
The sethi and or instructions generate R_SPARC_TLS_LE_HIX22 and R_SPARC_TLS_LE_LOX10 relocations respectively. The link-editor binds these relocations directly to the static TLS offset for the symbol defined in the executable. No relocation processing is required at runtime.
