The secure directory from which files can be preloaded is now /usr/lib/secure for 32–bit objects and /usr/lib/secure/64 for 64–bit objects. See Security.
Greater flexibility in modifying the runtime linker's search paths can be achieved with the link-editor's -z nodefaultlib option, and runtime configuration files created by the new utility crle(1). See Directories Searched by the Runtime Linker and Configuring the Default Search Paths.
The new EXTERN mapfile directive enables you to use -z defs with externally defined symbols. See Defining Additional Symbols.
The new $ISALIST, $OSNAME, and $OSREL dynamic string tokens provide greater flexibility in establishing instruction set specific, and system specific dependencies. See Dynamic String Tokens.
The link-editor options -p and -P provide additional means of invoking runtime link auditing libraries. See Recording Local Auditors. The runtime link auditing interfaces la_activity() and la_objsearch() have been added. See Audit Interface Functions.
A new dynamic section tag, DT_CHECKSUM, enables you to coordinate ELF files with core images. See Table 7–42.
