The Solaris software groups are collections of Solaris packages. Each software group includes support for different functions and hardware drivers. You select the software group to install, based on the functions that you want to perform on the system.
Core System Support Software Group – Contains the minimum code that is required to boot and run a networked Solaris system.
End User Solaris Software Group – Contains the minimum code that is required to boot and run a networked Solaris system and the Common Desktop Environment.
Developer Solaris Software Group – Contains the End User Software Group plus additional support for software development. The additional software development support includes libraries, include files, man pages, and programming tools. Compilers are not included.
Entire Solaris Software Group – Contains the Developer Solaris Software Group and additional software that is needed for servers.
Entire Solaris Software Group Plus OEM Support – Contains the Entire Solaris Software Group plus additional hardware drivers, including drivers for hardware that is not on the system at the time of installation.
When you are installing the Solaris software, you can choose to add or remove packages from the Solaris software group that you selected. When you are selecting which packages to add or remove, you need to know about software dependencies and how the Solaris software is packaged.
The following table lists the Solaris software groups and the recommended amount of disk space that you need to install each group.
The following disk space recommendations include space for the following items.
Swap space
Patches
Additional software packages
You might find that the following software groups require less disk space than the amount that is listed in the following table.
Software Group |
Recommended Disk Space |
Entire Solaris Software Group Plus OEM Support |
2.9 Gbytes |
Entire Solaris Software Group |
2.7 Gbytes |
Developer Solaris Software Group |
2.4 Gbytes |
End User Solaris Software Group |
2.0 Gbytes |
Core System Support Software Group |
2.0 Gbytes |
