Solaris 9 4/04 Installation Guide
Digital Certificate Requirements
If you want to add security to your WAN boot installation, you can use digital certificates to enable server and the client authentication. WAN boot can use a digital certificate to establish the identity of the server or the client during an online transaction. Digital certificates are issued by a certificate authority (CA). These certificates contain a serial number, expiration dates, a copy of the certificate holder's public key, and the certificate authority's digital signature.
If you want to require server or both client and server authentication during your installation, you must install digital certificates on the server. Follow these guidelines when you use digital certificates.
For detailed instructions on how to use PKCS#12 certificates during your WAN boot installation, see Using Digital Certificates for Server and Client Authentication.
