The WAN boot installation method can use PKCS#12 files to perform an installation over HTTPS with server or both client and server authentication. For requirements and guidelines about using PKCS#12 files, see Digital Certificate Requirements.
To use a PKCS#12 file in a WAN boot installation, you perform the following tasks.
Split the PKCS#12 file into separate SSL private key and trusted certificate files.
Insert the trusted certificate in the client's truststore file in the /etc/netboot hierarchy. The trusted certificate instructs the client to trust the server.
(Optional) Insert the contents of the SSL private key file in the client's keystore file in the /etc/netboot hierarchy.
The wanbootutil command provides options to perform the tasks in the previous list.
Before you split a PKCS#12 file, create the appropriate subdirectories of the /etc/netboot hierarchy on the WAN boot server.
For overview information that describes the /etc/netboot hierarchy, see Storing Configuration and Security Information in the /etc/netboot Hierarchy.
For instructions about how to create the /etc/netboot hierarchy, see Creating the /etc/netboot Hierarchy on the WAN Boot Server.
Assume the same user role as the web server user on the WAN boot server.
Extract the trusted certificate from the PKCS#12 file. Insert the certificate in the client's truststore file in the /etc/netboot hierarchy.
# wanbootutil p12split -i p12cert \ -t /etc/netboot/net-ip/client-ID/truststore |
Option to wanbootutil command that splits a PKCS#12 file into separate private key and certificate files.
Specifies the name of the PKCS#12 file to split.
Inserts the certificate in the client's truststore file. net-ip is the IP address of the client's subnet. client-ID can be a user-defined ID or the DHCP client ID.
(Optional) Decide if you want to require client authentication.
If yes, continue with the following steps.
If no, go to Creating a Hashing Key and an Encryption Key.
Insert the client certificate in the client's certstore.
# wanbootutil p12split -i p12cert -c \ /etc/netboot/net-ip/client-ID/certstore -k keyfile |
Inserts the client's certificate in the client's certstore. net-ip is the IP address of the client's subnet. client-ID can be a user-defined ID or the DHCP client ID.
Specifies the name of the client's SSL private key file to create from the split PKCS#12 file.
Insert the private key in the client's keystore.
# wanbootutil keymgmt -i -k keyfile \ -s /etc/netboot/net-ip/client-ID/keystore -o type=rsa |
Inserts an SSL private key in the client's keystore
Specifies the name of the client's private key file that was created in the previous step
Specifies the path to the client's keystore
Specifies the key type as RSA
In the following example, you use a PKCS#12 file to install client 010003BA152A42 on subnet 192.168.255.0. This command sample extracts a certificate from a PKCS#12 file that is named client.p12. The command then places the contents of the trusted certificate in the client's truststore file.
Before you execute these commands, you must first assume the same user role as the web server user. In this example, the web server user role is nobody.
server# su nobody Password: nobody# wanbootutil p12split -i client.p12 \ -t /etc/netboot/192.168.255.0/010003BA152A42/truststore nobody# chmod 600 /etc/netboot/192.168.255.0/010003BA152A42/truststore |
