The following nonstandard-input key sequences for the Euro character in Solaris Unicode/UTF-8 locales might not be supported in a future release:
Alt-E
Alt-4
Alt-5
Meta-E
Meta-4
Meta-5
In the key sequences, a hyphen indicates simultaneous keystrokes. A plus sign indicates consecutive keystrokes.
The following are the recommended standard-input key sequences:
Alt Graph-E
Compose+C+=
If the keyboard has no Alt Graph or Compose key, use the following key sequence:
Ctrl-Shift-T+C+=
