Solaris 9 4/04 Release Notes
Sort Capability in the European UTF-8 Locales Does Not Function Correctly (4307314)
The sort capability in the European UTF-8 locales does not work properly.
Workaround: Before you attempt to sort in a FIGGS UTF-8 locale, set the LC_COLLATE variable to the ISO–1 equivalent.
# echo $LC_COLLATE
>  es_ES.UTF-8
# LC_COLLATE=es_ES.IS08859-1
# export LC_COLLATE
Then start sorting.
