If you attempt to configure replication over SSL with certificate-based authentication, replication does not work if either of the following conditions exist:
The supplier's certificate is self-signed.
The supplier's certificate is only capable of behaving as an SSL server certificate that is unable to play the role of the client during an SSL handshake.
Workaround: None.
