Solaris 9 4/04 Release Notes
SPARC: Using fssnap on a Multiterabyte UFS File System Does Not Work (4836824)
Using the fssnap command to create a snapshot of a UFS file system that is greater than 1 Tbyte in size is not supported in the Solaris 9 4/04 release. The following error message is displayed:
fssnap: Fatal: File system /dir/snapshot0 support large files.
Workaround: None.
