dtmail crashes after connecting with the IMAP server if the FontList option is specified when dtmail is launched from the command line. See the following example:
/usr/dt/bin/dtmail -xrm "Dtmail*FontList: -*-r-normal-*:" |
The following error message is displayed:
Segmentation Fault |
This problem occurs in both the C and ja locales.
Workaround: Do not specify the FontList option when you launch dtmail from the command line.
