The following example shows how to extract the /etc/passwd and /etc/shadow files from the backup tape.
# cd /var/tmp # ufsrestore if /dev/rmt/0 ufsrestore> ls .: .cpr_config etc/ lost+found/ sbin/ TT_DB/ export/ mnt/ tmp/ b/ home/ net/ usr bin kernel/ opt/ var/ dev/ lib platform/ vol/ devices/ license/ proc/ ufsrestore> cd etc ufsrestore> add passwd shadow ufsrestore> verbose verbose mode on ufsrestore> extract Extract requested files You have not read any volumes yet. Unless you know which volume your file(s) are on you should start with the last volume and work towards the first. Specify next volume #: 1 extract file ./etc/shadow extract file ./etc/passwd Add links Set directory mode, owner, and times. set owner/mode for `.'? [yn] n ufsrestore> quit # |
