You can determine which system types are appropriate for your environment by comparing each system type based on the following characteristics:
Centralized Administration
Can the system be treated as a field-replaceable unit (FRU)? This means that a broken system can be quickly replaced with a new system without any lengthy backup and restore operations and no loss of system data.
Does the system need to be backed up? Large costs in terms of time and resources can be associated with backing up a large number of desktop systems.
Can the system's data be modified from a central server?
Can the system be installed from a centralized server, quickly and easily, without handling the client system's hardware?
Performance
Does this configuration perform well in desktop usage?
Does the addition of systems on a network affect the performance of other systems already on the network?
Disk Space Usage
How much disk space is required to effectively deploy this configuration?
This table describes how each system type scores in terms of each category. A ranking of 1 is most efficient. A ranking of 4 is least efficient.
Table 7–2 Comparison of System Types
System Type |
Centralized Administration |
Performance |
Disk Usage |
Standalone System |
4 |
1 |
4 |
Diskless Client |
1 |
4 |
1 |
AutoClient System |
1 |
2 |
2 |
Appliance |
1 |
1 |
1 |
