You can use the smosservice and smdiskless commands to add and maintain diskless client support on a network. By using a name service, you can manage system information in a centralized manner so that important system information, such as host names, does not have to be duplicated on every system in the network.
You can do the following tasks with the smosservice and smdiskless commands:
Add and modify diskless client support
Add and remove OS services
Manage diskless client information in the LDAP, NIS, NIS+, or files environment
You can only use the diskless client commands to set up diskless client booting. You cannot use them to set up other services, such as remote installation or profile services. Set up remote installation services by including diskless client specifications in the sysidcfg file. For more information, see Solaris 9 12/03 Installation Guide.
By writing your own shell scripts and using the commands shown in the following table, you can easily set up and manage your diskless client environment.
Table 7–3 Diskless Client Commands|
Command |
Subcommand |
Task |
/usr/sadm/bin/smosservice |
add |
Add OS services |
delete |
Delete OS services |
list |
List OS services |
patch |
Manage OS service patches |
/usr/sadm/bin/smdiskless |
add |
Add a diskless client to an OS server |
delete |
Delete a diskless client from an OS server |
list |
List the diskless clients on an OS server |
modify |
Modify the attributes of a diskless client |
You can obtain help on these commands in two ways:
Use the -h option when you type the command, subcommand, and required options. For example, to display the usage statement for smdiskless add type the following:
% /usr/sadm/bin/smdiskless add -p my-password -u my-user-name -- -h |
View the smdiskless(1M) or smosservice(1M) man pages.
You can use the smosservice and smdiskless commands as superuser. If you are using Role-Based Access Control (RBAC), you can use of either a subset or all of the diskless client commands, according to the RBAC rights to which they are assigned. The following table lists the RBAC rights that are required to use the diskless client commands.
Table 7–4 Required Rights For Diskless Client Management|
RBAC Right |
Command |
Task |
Basic Solaris User, Network Management |
smosservice list |
List OS services
smosservice patch |
List OS services patches |
smdiskless list |
List diskless clients |
smdiskless add |
Add diskless clients |
System Administrator |
All commands |
All tasks |
A Solaris OS server is a server that provides operating system (OS) services to support diskless client systems. You can add support for an OS server or convert a standalone system to an OS server with the smosservice command.
For each platform group and Solaris release that you want to support, you must add the particular OS service to the OS server. For example, if you want to support SPARC Sun4m systems running the Solaris 8 release, you must add Sun4m/Solaris 8 OS services to the OS server. You would also still need to add OS services to support SPARC Sun4c systems or x86 based systems that runs the Solaris 8 release, because they are different platform groups.
You must have access to the appropriate Solaris CD or disk image to add OS services.
When adding OS services to an OS server, you might see error messages saying that you have inconsistent versions of the OS running on the server and the OS that you are trying to add. This message occurs when the installed version of the OS has packages that were previously patched and the OS services being added do not have those packages patched (because the patches have been integrated into the packages).
For example, you may have a server that is running the Solaris 7 release. You may also have additional OS services loaded on this server, including the Solaris 2.6 SPARC sun4m OS services that have been patched. If you try to add the Solaris 2.6 SPARC sun4c OS services from a CD-ROM to this server, you could get the following error message:
Error: inconsistent revision, installed package appears to have been patched resulting in it being different than the package on your media. You will need to backout all patches that patch this package before retrying the add OS service option. |
