System Administration Guide: Basic Administration
Specifying the Disk Subdirectory
Disk and file administration commands require the use of either a raw (or character) device interface, or a block device interface. The distinction is made by how data is read from the device.
Raw device interfaces transfer only small amounts of data at a time. Block device interfaces include a buffer from which large blocks of data are read at once.
Different commands require different interfaces.
The following table shows which interface is required for some commonly used disk and file system commands.
Table 30–1 Device Interface Type Required by Some Frequently Used Commands
Command
Interface Type
Example of Use
df(1M)
Block
df /dev/dsk/c0t3d0s6
fsck(1M)
Raw
fsck -p /dev/rdsk/c0t0d0s0
mount(1M)
Block
mount /dev/dsk/c1t0d0s7 /export/home
newfs(1M)
Raw
newfs /dev/rdsk/c0t0d1s1
prtvtoc(1M)
Raw
prtvtoc /dev/rdsk/c0t0d0s2
