System Administration Guide: Basic Administration
x86: Disks With Direct Controllers
To specify a slice on a disk with an IDE controller on an x86 based system, follow the naming convention shown in the following figure.
Figure 30–2 x86: Disks with Direct Controllers
Diagram of device name for disks with direct controllers that includes logical controller, drive, and slice or fdisk partition.
To indicate the entire Solaris fdisk partition, specify slice 2 (s2).
If you have only one controller on your system, w is usually 0.
