This section describes USB driver enhancements in this Solaris release.
New generic USB driver (ugen) features and support – USB devices can now be accessed and manipulated by applications using standard Unix read(2) and write(2) system calls, and without writing a special kernel driver. Additional features include:
Applications have access to raw device data and device status.
Supports control, bulk, and interrupt (in and out) transfers.
Support for ugen is only available on ports operated by the USBA 1.0 framework.
To discover whether a port is operated by the USBA 1.0 framework, plug the device into the port. Then, issue the prtconf -D command. The prtconf -D hierarchy tree shows the device on the port, which is currently unbound to a driver, as device. Traverse up the prtconf hierarchy tree until you see an entry that has a driver with ohci, ehci, or uhci in its name. The ohci, ehci, or uhci entry represents the host controller. If the host controller driver name begins with usba10_, the devices in it's subtree are operated by the USBA 1.0 framework.
For more information, refer to the ugen(7D) man page and the USB DDK at:
http://developers.sun.com/solaris/developer/support/driver/usb.html |
Digi Edgeport USB support – Provides support for several Digi Edgeport USB to serial port converter devices.
New devices are accessed as /dev/term/[0-9]* and /dev/cua/[0-9]*.
USB serial ports are usable as any other serial port would be, except that they cannot serve as a local serial console. The fact that their data is run through a USB port is transparent to the user.
x86 platforms – The Digi Edgeport USB serial driver is supported only on the USBA 1.0 framework. See the preceding section on ugen for information on determining how to tell which framework operates which ports.
For more information, see usbser_edge(7D), or go to http://www.digi.com and http://www.sun.com/io.
Documentation and binary support for user-written kernel and userland drivers – A Solaris USB Driver Development Kit (DDK) is available, and its documentation is applicable to the Solaris 10 release. For up-to-date information on USB driver development, including information on the DDK, go to:
Features of the EHCI driver include:
Complies with enhanced host controller interface that supports USB 2.0.
Supports high-speed control, bulk, and interrupt transfers.
Currently, there is no support for high-speed isochronous transactions. It is possible that some USB audio devices might eventually use high-speed isochronous transactions.
If there are USB 2.0 and USB 1.x devices on the system, the EHCI and OHCI drivers hand-off device control depending upon the type of device that is connected to the system.
The USB 2.0 PCI card has one EHCI controller and one or more OHCI controllers.
A USB 1.1 device is dynamically assigned to the OHCI controller when it is plugged in. A USB 2.0 device is dynamically assigned to the EHCI controller when it is plugged in.
