Use the following error messages and solutions to troubleshooting problems with EFI-labeled disks.
The capacity of this LUN is too large. Reconfigure this LUN so that it is < 2TB. |
You attempted to create a partition on a SCSI device that is larger than 2 terabytes.
Create a partition on a SCSI device that is less than 2 terabytes.
Dec 3 09:26:48 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/ sf@1,0/ssd@w50020f23000002a4,0 (ssd1): Dec 3 09:26:48 holoship disk has 2576941056 blocks, which is too large for a 32-bit kernel |
You attempted to boot a system running a 32-bit SPARC kernel with a disk greater than 1 terabyte.
Boot a system running a 64-bit SPARC kernel with a disk greater than 1 terabyte.
Dec 3 09:12:17 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/ sf@1,0/ssd@w50020f23000002a4,0 (ssd1): Dec 3 09:12:17 holoship corrupt label - wrong magic number |
You attempted to add this disk to a system running an older Solaris release.
Add this disk to a system running the Solaris release that supports the EFI disk label.
