The following example displays slice information for disk with a VTOC label.
# format Searching for disks...done Specify disk (enter its number):1 Selecting c0t0d0 format> partition partition> print Current partition table (original): Total disk cylinders available: 8892 + 2 (reserved cylinders) Part Tag Flag Cylinders Size Blocks 0 root wm 1110 - 4687 1.61GB (0/3578/0) 3381210 1 swap wu 0 - 1109 512.00MB (0/1110/0) 1048950 2 backup wm 0 - 8891 4.01GB (0/8892/0) 8402940 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 unassigned wm 0 0 (0/0/0) 0 7 home wm 4688 - 8891 1.89GB (0/4204/0) 3972780 partition> q format> q # |
For a detailed description of the slice information in these examples, see Chapter 32, Managing Disks (Overview).
The following example shows the slice information on a disk with an EFI label.
# format Searching for disks...done Specify disk (enter its number): 9 selecting c4t1d0 [disk formatted] format> partition partition> print Current partition table (original): partition> q format> q Part Tag Flag First Sector Size Last Sector 0 root wm 34 300.00GB 629145633 1 usr wm 629145634 300.00GB 1258291233 2 unassigned wm 0 0 0 3 unassigned wm 0 0 0 4 unassigned wm 0 0 0 5 unassigned wm 0 0 0 6 usr wm 1258291234 628.77GB 2576924637 8 reserved wm 2576924638 8.00MB 2576941021 |
